Fiber constantly dropping
- Re: Fiber constantly dropping
27-09-2014 4:10 PM
Any help suggestions etc?
27-09-2014 4:20 PM
Are these devices which are dropping the connection wifi or wire connected?
There is every possibility that the drops are all related to wifi operation, not (as indicated by PlusNet's response) the FTTC service.
Proxy settings have no bearing on this issue.
27-09-2014 4:22 PM
27-09-2014 4:27 PM
all the lights on the techcolor router are green except the internet which is off
27-09-2014 4:32 PM
Try looking here and say what it says http://192.168.1.254/cgi/b/bb/?be=0&l0=2&l1=-1 about internet
However if the broadband light stays green when the connection drops it isn't a line problem
27-09-2014 4:41 PM
29-09-2014 1:24 PM
After reviewing your connection logs I can see that you're seeing drops every so often but these don't appear to be constant. Are you seeing disconnections outside of what we can see on the graph below?
<img src="http://community.plus.net/visualradius/generated/image1411993342695.png"/>
