Few days of very slow connection ADSL
- Few days of very slow connection ADSL
Re: Few days of very slow connection ADSL
12-08-2022 5:27 PM
Sorry, Ian, but it won't. ![]()
12-08-2022 5:33 PM
Amazingly frustrating! One after another. Seems to have settled this evening.
Does this mean back to square one, or just wait a bit longer?
12-08-2022 5:39 PM
@IanSn my suggestion, for what it's worth - wait another day, and if there is no change either contact PN as suggested or post back here - I have a 'check-list' we could use to determine if it was just the power cut, or something a bit more major.
12-08-2022 6:04 PM - edited 12-08-2022 6:05 PM
Yes, sounds sensible.
Thanks, it may just have been a coincidence that troubles started at same time as power-cut. I've been hoping it wasn't.
Speed is still slow this evening...
15-08-2022 5:44 PM
So. No change.
Tests results don't mean much to me, not my area of expertise, but I don't understand why I'm seeing these results.
I have a Q open on this but, before I get back to that, I need to know what I'm talking about, and why this report says there is no problem. There is.
I know there was a reset and I have to wait, but the line seems to be very stable - at a very slow speed.
Over 10 years with PlusNet, at these premises, I always had far better speeds than this so I know this isn't correct. Why is my profile set at this?
Other tests I've run (on this thread) have numbers up to 17.5. I accept I'm not likely to get that but 3.75?
There was an engineer here back in June sometime, he went to the exchange and did something with a card. It was back to normal after that. I didn't do tests then as everything seemed fine.
ian
15-08-2022 5:53 PM
@IanSn That is an abysmal set of figures - absolutely none of them are acceptable.
Sorry to ask for more information, but that in itself doesn't point in a useful direction. Can you pleas post a screen shot of this report (obscuring the phone number), and the Help Desk page from your Hub (hiding your Username) - hopefully that will be sufficient to see what is wrong, but forgive me in advance if I ask for anything else.
15-08-2022 6:37 PM - edited 15-08-2022 6:39 PM
Glad you agree!
Please don't apologise, you are a godsend...
Router stats -
Uptime -- it must have restarted
1 - Product name: Plusnet Router
2 - Serial number: N7200111B002752
3 - Firmware version: 7.275.17_F2704N_Plusnet
4 - Board version: F@ST2704N
5 - Mode ADSL
6 - Uptime: 0 days 12:07:57
7 - Data rate: 468/4543
8 - Maximum data rate: 832/21288
9 - Noise margin: 14.6/27.7
10 - Line attenuation: 10.3/18.5
12 - Data sent/received: 5.4M/73.2M
20 - Broadband username:
21 - Wi-Fi network/SSID: PLUSNET-
22 - Wi-Fi connections: Enable(802.11 b/g/n(up to 144 Mb/s))20 MHz WPS enabled
23 - Wi-Fi security: WPA2
24 - Wi-Fi channel: Automatic (Smart Wireless)
25 - Firewall: Default
26 - MAC Address: 64:66:24:59:f8:0a
27 - Software variant Version 1.0
28 - Boot loader: 7.275.11
The screenshot from that BTW test doesn't show any more than the pdf I posted (except that its now 3.19)
Is this the page you need?
15-08-2022 6:51 PM
Thanks, Ian. Your router Help Page makes for grim reading. the data rate - both directions, is horrible as are the SNR figures.
This needs further investigation by BT/OR - I suggest you initially report a fault via https://www.plus.net/help/report-a-problem/broadband/ , and report back what they say.
The screenshot is what I wanted, basically just to confirm the fault is within the BT/OR network, and nothing to do with you home one.
I don't know enough about the Hub0 (2704N), but does it report any error logs? If it does, it would be interesting to see what they say, but not essential, as you still have a problem.
15-08-2022 7:12 PM
Doesn't seem to be any error-reporting on this router. I was sent this one earlier this year to replace a dead one.
Yes, I reported a fault on this link and that was when it was reset, and thus this wait. She seemed to think it just needed a reset to fix the problem. I'll need to get back to them now. Seems to be done by text these days, but I did get a call back. I'll keep these results to repeat at them, tho they don't mean much to me!
Thanks for your help!
v best, ian
15-08-2022 7:20 PM
Didn't think there was any error logs on there, to be honest, but it was worth a shot. how long have you got to the end of this contract? They really should have sent you a Hub1, but no matter, for the moment.
From that BTW Availability screen-shot, I would say the problem was not caused by the power-cut(s), although they won't have helped - IIRC the speed they report is obtained from BT test equipment which gets its information from your connection, not your Hub.
If they call you back, insist on a OR visit - no amount of resets will sort this.
15-08-2022 7:26 PM
Hi @IanSn,
I'm sorry about the slow connection speeds, I've just checked your account and can see that's happened due to the connection dropping out quite frequently.
Line tests don't show any obvious causes so can you make sure you've followed the checks outlined here as your next step please?
https://www.plus.net/help/broadband/connection-troubleshooting/
15-08-2022 7:37 PM - edited 15-08-2022 7:37 PM
@adamwalker I don't want to teach granny how to suck eggs, but the speed result on the BTW Availability checker shows (to me, at least), that there is a fault/error somewhere outside the OPs environment - unless you know better?
15-08-2022 7:37 PM
Adam, all these items ticked.
Should I send that text back to the advisor now?
ian
15-08-2022 10:03 PM
Pure speculation on my part, but my perception is that the software/firmware managing DLM has recently become overly 'sensitive'. I've other (connected) hypotheses.
Thinking forward...
With people worrying about power/utility bills (and whether they will be able to pay them), people will be powering down stuff they are not actively using. Perhaps the DLM software/firmware needs to be less sensitive to line drops unless BT/OR can defintively indicate that the line drop is due to a network problem (and most likely outside of customer's premises)?
15-08-2022 10:33 PM
Maybe my assumption is wrong but I thought that if you log in to the hub and select disconnect it advised the interconnected infrastructure that this was an intentional shut down and not a dropped connection?
Rather like the difference between shutting down a computer properly and pulling out the plug whilst the computer is still processing data.
