Fed up with Slow speed also
- Fed up with Slow speed also
26-04-2011 7:42 PM
New Dropper line outside, new faceplate & I-plate and terminals have been reconnected.
I have a Thomson Wireless Modem/Router plugged into the master socket via a I plate so have no microfilters. I have Panasonic DECT phones and BT phone on a doubler into the phone socket. There is no other wiring. disconnecting the phone isn't really an option, but willing to listen to suggestions.
In the history with Plusnet here are pictures of the line performance which show instantaneous dropouts at odd times yet at other times 22 days no dropouts on my history with plusnet.
Product Name: TG585 v7
Software Release: 8.2.6.5
Link Information
Uptime: 1 day, 8:47:37
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 160
Output Power (Up/Down) [dBm]: 12.0 / 13.0
Line Attenuation (Up/Down) [dB]: 26.5 / 42.0
SN Margin (Up/Down) [dB]: 16.0 / 33.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Framing (Local/Remote): 883 / 0
Loss of Signal (Local/Remote): 322 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 705 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Post code PA23 8JU
They are suggesting to try a different router as BT tests are O.K. any idea what would be a good router to try in view distance from the exchange.
Any other ideas or comments. Plusnet not come up with a fix so far over several months.
(we have tried directly into the Test socket no difference in speed.)
Cal
Re: Fed up with Slow speed also
26-04-2011 7:49 PM
with thoses stats 7mbps is possible for sure.
26-04-2011 8:00 PM
26-04-2011 8:08 PM
Actually on your line the DG834Gv5 may be OK - it isn't too good on longer lines
EDIT - I think I see your problem
The iPlate isn't a filter - you need filters as well or do you mean a filtered faceplate
27-04-2011 10:40 AM
The Filtered faceplate is fitted, one with two sockets, one for phone and one for ADSL, I also have a spare of another make, there were questions in the past about the backing plate which was changed on the last but one visit.
Gone for a second hand 834G V4 off ebay although I see you go for V5. Thanks for the advice.
Cal
02-05-2011 6:07 PM
System Up Time 97:41:00
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 37147 42713 0 16 82 93:39:09
LAN 10M/100M 16899 0 0 8 0 97:40:54
WLAN 11M/54M 80298 73353 0 138 34 97:40:46
ADSL Link Downstream Upstream
Connection Speed 192 kbps 448 kbps
Line Attenuation 44.0 db 26.5 db
Noise Margin 32.9 db 18.0 db
Any ideas on this? Old Jim?
cheers
C
02-05-2011 6:13 PM
Either you have a banded line - unlikely if you are on ADSL1 - or there is some horrible intermittent noise from an unfiltered device.
Can you connect the router to the test socket with a standard filter and see what happens
02-05-2011 11:08 PM
03-05-2011 10:40 AM
Both into ADSL Nation microfilter. DECT into phone and Router into ADSL
stem Up Time 00:24:15
WAN PPPoA 1190 1431 0 168 727 00:22:41
LAN 10M/100M 242 0 0 26 0 00:24:09
WLAN 11M/54M 2974 2650 0 1098 310 00:24:01
Connection Speed 7424 kbps 448 kbps
Line Attenuation 44.0 db 26.0 db
Noise Margin 6.4 db 22.0 db
03-05-2011 10:51 AM
03-05-2011 11:06 AM
redone terminations. I still have a Tamar faceplate, but for moment living in the test socket and see if the profile comes up. cheers Cal
03-05-2011 5:09 PM
I'm surprised it's not come up yet. I'll check again in the morning and if it's not up then I'll considering resetting the SNR which usually kicks it into action.
Jojo
03-05-2011 7:39 PM
nice of you to keep an eye on things
Cal
04-05-2011 9:23 AM
Resetting the SNR seems to have done the trick. Your profile is now 6000k. You should see the speed increase shortly.
Jojo
04-05-2011 9:52 AM
too.
Cal
