Faulty Router?
- Faulty Router?
Faulty Router?
11-02-2017 8:58 AM
Twice recently I have gone to use computer 1st thing in the morning and I get report saying that the SSID cannot be found. The lights are all OK on router and it affects all devices, phone, TV, the lot.
Reboot router and it all works again.
Is this a sign of a faulty router?
Re: Faulty Router?
11-02-2017 9:07 AM - edited 11-02-2017 9:07 AM
I would advise factory resetting the router first and seeing if it improves, also which router are you using?
James
Re: Faulty Router?
11-02-2017 1:25 PM
It's the basic Technicolor router. I'll try a factory re-set - though perhaps I'll just have a look at all the configured devices in case there's some I can remove in case that's the problem. Trouble is it is just a random issue that I've never seen before.
Re: Faulty Router?
11-02-2017 2:08 PM
If you use google chrome on that PC, as crazy as it may sound, have a read of this
Your symptoms sound very similar....
(you can skip to the bottom of the first page as I did waffle on a bit first)
The other thing to do is check for wifi congestion.
