Faults.plus.net is DOWN?
- Re: Faults.plus.net is DOWN?
29-07-2014 9:04 AM
I am trying to submit a fault using Faults.plus.net. I cannot see this site from my home or my office machine.
http://www.isitdownrightnow.com/ tell me the site is down. (Faults.plus.net is DOWN for everyone. It is not just you. The server is not responding...)
The friendly chap at Plusnet telephone support was insistent it was up, and didn't seem to want to look into this.
Am I going crazy?
29-07-2014 9:08 AM
Phil
29-07-2014 9:17 AM
http://faults.plus.net is definitely up, I've just checked for anything being flagged on our internal monitoring systems which isn't alerting us to any issues either. Does the page just time out when you try to access it?
29-07-2014 9:20 AM
After about a minute...
Broadband Troubleshooter - Error
There's been a problem
Please try using the Broadband Troubleshooter again in a short while. If you continue to have problems please contact our Support Team for help.
29-07-2014 9:24 AM
29-07-2014 9:26 AM
Maybe I am going crazy!
29-07-2014 9:29 AM
I think there's an issue with the Broadband Fault Checker on your account - I'm not sure what it is, but we'll get it looked at, I'm wondering if the Broadband Fault Checker is trying to get access to your line details to run a line check but it eventually times, out errors and chucks out a ticket to our Faults Team for manual testing, which is what's happened.
We'll get that looked at for you and the Faults Team will be in touch in due course.
