Fault *not* fixed - need SNR reset please
ITWorks
Fixes: 9
Had a BTOR telephone engineer this morning to fix a no dial tone fault. This has now been fixed. Due to the fault my SNR has risen from 6 to 12.5 , giving a sync of 2304,
Can someone, give me a SNR reset please  Smiley ?
I did ask the engineer if he could do the SNR reset, but he could not ( i assume because he was telephone engineer rather  than broadband.)
The engineer left about 25 min ago.
Regards
Mike
5 REPLIES 5
adamwalker
Fixes: 221
Re: Fault fixed - need SNR reset please
I've just submitted the reset. I'll run a line test in a few minutes to check that's taken effect so I can then adjust the profile.
 Adam Walker
ITWorks
Fixes: 9
Hi Adam,
I can see the reset has been done, SNR down 6, something appears to be a miss , before this fault i had been syncing at between 6500 - 7300 ( last few years ).
here are my current stats
ADSL Link Downstream Upstream
Connection Speed 3680 kbps 448 kbps
Line Attenuation 39.0 db 20.5 db
Noise Margin 6.1 db 21.0 db
On those basic stats the only difference before the fault is the sync.  On these stats my line should sync much higher , ( last sync before fault 6912)
Regards
Mike
adamwalker
Fixes: 221
In that case I'll check again in another couple of hours time as it's likely that the profile will increase again during that time. I've set our profile at 3000kbps to bring it in line with BT's.
 Adam Walker
ITWorks
Fixes: 9
Okay, thanks Adam
Update : This is now back with faults ( just spoke with them), waiting for call back ( info added to ticket)
Regards
Mike
adamwalker
Fixes: 221
Re: Fault *not* fixed - need SNR reset please
Cheers for letting me know, they should get that sorted for you. Any issues just let me know.
Adam
 Adam Walker
