Fault charges
glloyd
Fault charges
Why do ISP's have to pay openreach to fix faults?  Surely that's all covered in line rental etc.
Fixes: 162
Re: Fault charges
I believe we only pay if the fault is caused by the customer's equipment, wiring etc, the visits are only chargeable where the fault is not caused by Openreach.
 Chris Parr
 Plusnet Staff
pvmb
Re: Fault charges
It is covered by "line rental etc" if the fault is unambiguously in the Openreach network system. This includes everything in the local loop up to - BUT NOT BEYOND -  the consumers Network Terminating Equipment (NTE) fixture at the consumer's premises.
This is the BT/Openreach NTE in your premises. If you have a NTE5 master socket then you will need to remove the bottom faceplate to break the connection between your home wiring and the Openreach network to establish where the fault lies to avoid the charge. NB - If the fault is in the consumer removable bottom faceplate itself, then it is deemed (AFAIK) to be a fault in the consumers side wiring. i.e. You pay. Smiley
Apologies if you already know all this.
The average consumer has never actually had this clearly pointed out to them.
Fixes: 10
Re: Fault charges
BT Wholesale try to make ISPs pay towards the investigation of broadband faults by only providing the ability to report faults by ordering a chargeable service.
See https://www.youtube.com/watch?v=YFdZcEx8oog
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
JayG
Re: Fault charges
 It's also the case that if the engineer reports 'no fault found', Plusnet, and subsequently you, will be charged the callout fee (£65 charge to the customer, probably around double that to PN.)
Plusnet Staff
Plusnet Staff
Fixes: 116
Re: Fault charges
When we report a fault, as a company we have to agree to engineering time related charges if there is no fault with the BT network. If applicable, I believe we do only pass on a portion of this charge to customers.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
pvmb
Re: Fault charges
Yeah. That's the 'killer' with this whole arrangement AFAIAC.
glloyd
Re: Fault charges
That's terrible it makes ISP's reluctant to report a fault so make customers suffer poor service instead.
Fixes: 180
Re: Fault charges
It's not that we're reluctant to report faults, however it is why we stress that the customer should go through the troubleshooting guides in the first instance to try and rule out their equipment or internal wiring.
Following this, it's also why we must have acceptance from the customer that there will be a charge if, off the back of an engineer appointment, the fault is found to be with their own internal wiring or equipment.
 Harry Beesley
