Fault Threshold Rate
Steevo
Please could someone explain to me the relevance of the MSR and FTR statistics.
How do they compare to the actual broadband speed that should be expected when running a computer speed test?
19 REPLIES 19
npr
Fixes: 9
Re: Fault Threshold Rate
Steevo
Thanks, that explains it as I seemed to understand it. The reason I ask is my line test shows up:
Maximum Stable Rate (KBPS): 6816
Fault Threshold Rate (KBPS): 5452
But my speed is only running at 1400, and nobody seems to bothered about it as BT Speedtest claims are up to 1mbps.
Am I missing something? Surely if FTR is 5.4mbps, that is what my line should be capable of recieiving?
Steevo
My IP profile is also set at 1.3mbps, but historically my speeds have been 50% higher than this.
Steevo
Nobody?
RealAleMadrid
Aspiring Hero
Fixes: 59
Never mind MSR and FTR, post your full router stats, connection speeds, attenuation etc. Or raise a speed fault with PLUSNET
Steevo
Quote from: RealAleMadrid
Why do you say never mine MSR and FTR? Surely they are relevant? As I understand it from the link posted earlier line speed should be above FTR, but I was hoping someone could confirm this for me.
How do I find full stats (e.g. attenuation) on a TP Link router please? All I can find is line rate.
Anotherone
Champion
Fixes: 21
Which model? And have you try a reboot?  - just one, not repeated ones which will make things worse.
Steevo
Thanks for the reply.
TD-W8960N v3
Yes, I have tried a single router reboot but to no avail.
Steevo
Previously when watching a video on YouTube for example my speed used to rise to the max speed, and flatline until it reached the end of the download. Now my speed seems to fluctuate quite a bit at max level, leaving a more jagged line, and also suffers from speed drops before recovering again. It cannot maintain a constant speed.
Anotherone
Champion
Fixes: 21
Can you hear any crackling or other noises on the phone line when using the phone? If so report a phone fault, but don't mention the broadband or you get the run around.
npr
Fixes: 9
Can you please post the routers adsl stats.
Are the speed tests do via wireless or wired?
Steevo
Quote from: npr
Please advise how to get the stats you require from the TP Link TD-W8960N v3.
All tests done via wired.
Steevo
Quote from: Anotherone
There is a very small bit of background noise if you listen hard but nothing major. i.e. it's not dead silent but probably 98%.
Steevo
Another example of speed randomness.
