Fault Checker
- Fault Checker
Fault Checker
28-11-2007 10:28 AM
Re: Fault Checker
28-11-2007 10:36 AM
What difference would it have where you bought your kit from?
I suspect that this may be a concern raised as the result of an ambiguous message - what exactly did the fault checker say?
Which checker are you referring to?
Re: Fault Checker
28-11-2007 10:37 AM
It doesn't really matter where you get the hardware from. If you are suffering from a loss in connection then it is always possible that the hardware is faulty, whether you get it from PlusNet, eBay or the planet Zorg.
It's part of standard diagnosis work to ensure that you don't get stung with a £144+VAT charge from BT.
Can you tell me exactly what the fault checker said?
Re: Fault Checker
28-11-2007 10:51 AM
I would also like to no why two nights ago I couldn't get anyone on your support line after easily 15/20 minutes when this problem started. Are the support lines even manned around 11:30pm?
Re: Fault Checker
28-11-2007 10:53 AM
Re: Fault Checker
28-11-2007 10:54 AM
Re: Fault Checker
28-11-2007 10:56 AM
Re: Fault Checker
28-11-2007 11:00 AM
I appreciate that your connection is dropping and am very sorry for that.
Is it possible for you to change your microfilters, ensure that you are connecting via your master socket and use a friends modem of possible?
Also, you will need to complete the Broadband Fault Checker, if it doesn't get completed, the fault get closed within 48 hours.
Let us know and we should be able to help further.
Re: Fault Checker
28-11-2007 11:06 AM
How does one get it to ask such a question?
Re: Fault Checker
28-11-2007 11:09 AM
- I have checked EVERYTHING here
- I have unplugged the two other phones connected to my line
- I have reconnected each phone in turn
- I have swapped over microfilters, in turn
- I have rebooted my router each time
- I HAVE completed your fault checker (see first post) and YOUR fault checker has already closed the report and tagged it as "closed"
- I consider it highly unlikely that my router is faulty and more likely it is the line and/or your gateway servers.
I don't see what else I, as a customer, can do but I'm open to suggestions. No, I don't have a spare router at hand.
Re: Fault Checker
28-11-2007 11:18 AM
You're actually on our Tiscali LLU service, which is good in a way because we have greater control over your profiling than we would on a normal BT circuit.
What I've done initially is to assign you to a high SNR 1Mbps profile. Can you let me know if your connection continues to drop? This isn't a permanant change, just part of the troubleshooting processes.
Re: Fault Checker
28-11-2007 11:24 AM
Re: Fault Checker
28-11-2007 11:35 AM
Re: Fault Checker
28-11-2007 11:52 AM
I can bump it up 2Mbps if you would like. It's a case of finding the optimal profile for your connection.
Re: Fault Checker
28-11-2007 11:56 AM
Yes please, bump it up to 2M and I will monitor (after I watch Broon getting slated at PMQ 🙂
Re "optimal profile": does this suggest a speed lower than the 4M I have got in the past?
