Fastpath not Interleaved
- Fastpath not Interleaved
07-03-2012 2:21 PM
Hi All,
This is my first day on Plusnet. I am a refugee from AAISP they were just too expensive.
The good news is that I am connected at 8128/448 kbps with ping times of 15ms. This indicates to me that I am on "Fastpath not Interleaved". I'm not complaing! It's just that all the Plusnet documentation suggests that Interleaving is the norm unless you ask for it to be switched off!
I have just confirmed "Fastpath" by telnetting into the router. It gooks pretty good to me.
BusyBox v0.61.pre (2008.06.11-10:37+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
# cat /proc/avalanche/avsar_modem_stats
AR7 DSL Modem Statistics:
[DSL Modem Stats]
US Connection Rate: 448 DS Connection Rate: 8128
DS Line Attenuation: 4 DS Margin: 13
US Line Attenuation: 3 US Margin: 24
US Payload : 28950864 DS Payload: 43265169
6
US Superframe Cnt : 539892 DS Superframe Cnt: 539893
US Transmit Power : 0 DS Transmit Power: 0
LOS errors: 0 SEF errors: 0
Errored Seconds: 0 Severely Err Secs: 0
Frame mode: 3 Max Frame mode: 0
Trained Path: 0 US Peak Cell Rate: 1056
Trained Mode: 3 Selected Mode: 1
ATUC Vendor Code: 414C4342 ATUC Revision: 1
Hybrid Selected: 3 Trellis: 1
Showtime Count: 1 DS Max Attainable Bit Rate: 11200 kbps
BitSwap: 1 US Max Attainable Bit Rate: n/a
Annex: AnxA psd_mask_qualifier: 0x0000
Power Management Status: L0 DS HLINSC: 0
US ACTPSD: -345 DS ACTPSD: -365
Total init. errors: 0 Total init. timeouts: 0
Showtime init. errors: 0 Showtime init. timeouts: 0
Last showtime init. errors: 0 Last showtime init. timeouts: 0
ATUC ghsVid: 0f 00 41 4c 43 42 00 00
T1413Vid: 00 00 T1413Rev: 00 VendorRev: 00
ATUR ghsVid: b5 00 54 53 54 43 00 00
[Upstream (TX) Interleave path]
CRC: 0 FEC: 0 NCD: 1
LCD: 0 HEC: 0
[Downstream (RX) Interleave path]
CRC: 0 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[Upstream (TX) Fast path]
CRC: 1 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[Downstream (RX) Fast path]
LCD: 0 HEC: 0
[ATM Stats]
[Upstream/TX]
Good Cell Cnt: 603143
Idle Cell Cnt: 9094539
Tx Packets Dropped Count: 0
Tx Bad Packets Count: 0
[Downstream/RX)]
Good Cell Cnt: 9013577
Idle Cell Cnt: 166930407
Bad Hec Cell Cnt: 0
Overflow Dropped Cell Cnt: 0
Rx Packets Dropped Count: 0
Rx Bad Packets Count: 0
[SAR AAL5 Stats]
Tx PDU's: 178223
Rx PDU's: 304105
Tx Total Bytes: 19952631
Rx Total Bytes: 422452815
Tx Total Error Counts: 0
Rx Total Error Counts: 0
[OAM Stats]
Near End F5 Loop Back Count: 0
Near End F4 Loop Back Count: 0
Far End F5 Loop Back Count: 0
Far End F4 Loop Back Count: 0
SAR OAM Ping Response Drop Count=0
[DSL Modem Stats]
6
LCD: 0 HEC: 0
LCD: 0 HEC: 0
LCD: 0 HEC: 0
LCD: 0 HEC: 0
[ATM Stats]
[Upstream/TX]
[Downstream/RX)]
Bad Hec Cell Cnt: 0
[SAR AAL5 Stats]
Tx PDU's: 178223
Rx PDU's: 304105
[OAM Stats]
Message 1 of 5
(1,305 Views)
4 REPLIES 4
Re: Fastpath not Interleaved
07-03-2012 2:25 PM
Interleaving is a form of error correction, your stats are all good and the equipment has decided that it doesn't need interleaving.
Be happy, especially if you game
Message 2 of 5
(532 Views)
07-03-2012 2:26 PM
Is ADSL2+ available at your exchange - if it is you could ask for an upgrade giving a useful speed increase
Message 3 of 5
(532 Views)
07-03-2012 2:33 PM
I live in the middle of nowhere. It's Market 1(20CN) for the forseeable future. I just happen to live right next to the telephone exchange.
I am happy!
I am happy!
Message 4 of 5
(532 Views)
07-03-2012 9:08 PM
Excellent news
Enjoy the extra cash in your pocket each month ... could be well spent on Scotch
Regards
Regards
Message 5 of 5
(532 Views)
