Faster upload speed required for XboxLive
Markhhuk
Quote from: Bob
You're line's provided on 20CN/ADSL1. It looks like you have one of our routers so I've placed an order to move you across to ADSL2+ with uncapped upload (up to 1.3Mbps dependent on line conditions). The order should complete at some point on the 27th September.
Hi I have a problem with my upload speed being to low to play xbox live as i actually get 330kbps but 500kbps is required as a minimum. I have used the exchange status checker and the results are below.
Exchange Status Checker
Results: Stewkley
Code: SMST
County: Buckinghamshire
Enabled: 30 Jun 2004
Market: 1
Mkt2014: A
Colour: Green 20CN VP capacity at this exchange is currently showing as Green.
Click here for further details
Colour: Red BT have not advised a planned date for WBC on 21CN
Colour: Unknown You can view recent Service Outages for this exchange here
Colour: Unknown BT have published Max DSL upgrade information for this exchange
My connection stats from my router are below which is ADSL2+ compatible.
Line Status:Connected
DSL Modulation Type:ADSL_G.dmt
Annex Type:Annex A/L
                        Upstream               Downstream
Current Rate (Kbps) 448                        8128
Max Rate (Kbps)        1156                 8128
SNR Margin (dB)         26                         12.7
Line Attenuation (dB) 11                         18.5
Errors (Pkts)        0                         0
Can my upload speed be increased please??
Many Thanks
Fixes: 341
Re: Faster upload speed required for XboxLive
only way you'll get faster upload speed is to get Max Premium on your account for about £10 a month as your exchange hasn't got adsl2+ or any other service.
that'd double your upload.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 62
Re: Change Upload Speed?
As your exchange hasn't been enabled for 21CN the only way to get higher upload is to buy this http://www.plus.net/support/broadband/products/prioritised-service-faq.shtml which gives 832kbps upload
Fixes: 62
Duplicate post removed from another thread and answers merged
Markhhuk
Quote from: Oldjim
Thank you for taking the time to help, i have used the link and signed up, hopefully will help with my lag. sorry for the duplicate.
wo0x
Let us know how you get on with the increased upload speed. Interested to see if a such a small increase in upload can really make a difference.
Plusnet Staff
Plusnet Staff
Fixes: 5
Hi Markhhuk,
I've updated your ticket - order has been placed.
Chris Pettitt
Cloud Environments Engineer
Markhhuk
Thank you Chris.
jim:quote
Markhhuk
Quote from: Wo0x
I will provide an update next week. I will go from being below the minimum threshold by 34% to being above it so hopefully it ill resolve my issue. At the moment i am unable to play battlefield 4 on the xbox one due to lag 90% of the time. Plusnet have confirmed my line is fine and i have tried 3 different routers, a direct cable to the router and port forwarding or dmz to name a few things but the issue is not resolved. Will let you know Thanks.
