Fast Path
ian007jen
Fast Path
Hello
I have a really steady connection with minimal errors, could I try fast path to see if my line can remain stable with lower latency.
Error stats
Since Link time = 25 days 10 hours 55 min 39 sec
FEC: 4194848 805
CRC: 22621 308
ES: 6644 0
SES: 243 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
Thanks in advance
Ian
ps # on account 96958448
10 REPLIES 10
Chris
Legend
Fixes: 169
Re: Fast Path
I've placed the modify order, this should complete on Monday. Let us know if you have any problems after that.
ian007jen
Re: Fast Path
Thanks......will do
Ian
ian007jen
Re: Fast Path
OK the fast path order seems to have stalled/failed, I have also added max premium (question #97379608), can somebody from crt take a look please.
I think the bt database has its knickers in a twist about my address, is it possible to remedy this duplication of address as well.
Thanks in advance
Ian
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Re: Fast Path
There's a current order in place stopping me making the change now. I've made a note of your details so I can fix everything for you tomorrow (assuming the current order completes).
Tony
 Tony T
ian007jen
Re: Fast Path
Well that did not work as expected
Current stats
Upstream line rate (kbit/s): 288
Downstream line rate (kbit/s): 1152
Old STATS
Upstream line rate (kbit/s): 448
Downstream line rate (kbit/s): 6880
I can see it is on fastpath, but fixed rate 1Mb/s not ADSL max, so max premium may have failed.
I presume orders today will complete on Monday.
Ian
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Re: Fast Path
I can see what's happened here. I'm correcting it now for you.
 Tony T
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Re: Fast Path
I'm sorry to bring bad news. You were placed on 1Mb fixed rather than Max Premium. It's not clear if your line will support 1Mbit upload, but we're trying this again for you now. The problem is, this order won't complete until Monday, at which point we can address the interleaving.
 Tony T
ian007jen
Re: Fast Path
Sync was dropped and reconnected again at about  09:30 back on ADSL max....with max premium.
Stats
Upstream line rate (kbit/s): 768
so about an extra 320 kbps upload
Ian
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Re: Fast Path
I hope everything is OK. Let us know if you need anything else changing.
Tony
 Tony T
ian007jen
Re: Fast Path
Thanks Tony
All fine.
I think I will not bother with fast path, it may make the line too unstable.
Ian
(closed ticked ref 97379608)
