Falling sync speed
- Re: Falling sync speed
Falling sync speed
09-01-2009 9:20 AM
Up until a few weeks ago my sync speed used to be around 4500 but over time it has dropped to about 2700. I used to be able to bring it up again by re starting the system ( re booting the router) bu now even this does not help.
I have not changed, added or taken anything away etc so it cannot be anything that i have done.
If anyone has any ideas what the cause may be and any possible remedies i would be very grateful.
Richard
09-01-2009 9:28 AM
09-01-2009 9:33 AM
• Outgoing: 448 kbps giving me a profile of 2000kbps. This used to be between 4 and 5mbps bust usually settling down at 3500kbps
09-01-2009 9:36 AM
DSL Line (Wire Pair): Line 1 (inner pair)
Protocol: G.DMT Annex A
Downstream Rate: 2848 kbps
Upstream Rate: 448 kbps
Channel: Interleaved
Current Noise Margin: 15.0 dB (Downstream), 18.0 db (Upstream)
Current Attenuation: 44.8 dB (Downstream), 24.5 db (Upstream)
Current Output Power: 19.8 dB (Downstream), 12.2 db (Upstream)
DSLAM Vendor Information: Country: {0xB5} Vendor: {TSTC} Specific: {0x00}
PVC Info: 0/38
These stats are the same as before the problems started
Hopefully this may help in diagnosing the problem
Richard
09-01-2009 10:12 AM
If the stats are pretty much the same, then you've had some issues causing you to drop sync and re-sync frequently. Start by having a check to see if you can hear any noise on your phone line. Any crackling or other intermitent noises that you can hear or have heard recently?
09-01-2009 10:30 AM
I just cannot make this out but something somewhere must have changed to make this happen.
Don't you just hate it when something like this happens for no obvious cause. I just hope that someone can help otherwise i'll be stuck with a lower speed and have to "put up with it"
Richard
09-01-2009 10:35 AM
Has your noise margin always been that high? It does seem rather high if you were previous receiving a faster speed. My initial assumption would have been that it had increased.
Can you please ensure that you are connecting directly to your master socket via a filter (test socket behind the master faceplate is best if possible) and try using a different microfilter.
That may help improve the quality of the signal a touch.
09-01-2009 10:50 AM
No need for filters etc as i have one of the new BT faceplates that has 2 sockets, one for the phone and the other for broadband.
Ha, so thats a couple more ideas out the window...........................unlkess i could talk PN into lowering the noise margin and seeing what happens then.........
09-01-2009 10:53 AM
Any chance of trying to borrow a router from a friend to see if you get the same noise margin / speed on the line?
09-01-2009 10:59 AM
I have another router, same make/model. I have already tried using it but the figures still come out the same.
If i try to raise a speed fault i go through all the checks and then it tells me that everything is alright. Can you tell me if i can bypass this and just ask PN to ask BT to lower the noise margin?
Regards
Richard
09-01-2009 10:59 AM
I was under the impression that raising a speed fault wasn't necessary to get the noise margin lowered given that a speed fault requires 3 BT speed tests which are a waste of time
09-01-2009 11:01 AM
09-01-2009 11:07 AM
Richard
09-01-2009 11:14 AM
09-01-2009 11:23 AM
have now sent request to PN to see if they can get the noise margin lowered.
Regards
Richard
