Failed 582n Firmware Upgrade, stuck on PPPoA
- Failed 582n Firmware Upgrade, stuck on PPPoA
18-02-2013 11:41 PM
I installed 10.2.9 or similar over 10.00.B or similar and the unit seems to have lost all PN config and is stuck on PPPoA.
Can someone email me the file or link to the correct firmware? I've downgraded to 8.4.4.J but still no PPPoE config so I'm worried I've broken it for good.
Worse case I need to get online ASAP tomorrow so may have to go to PC World to get a suitable VDSL? Router as my DG834G doesn't seem suitable.
Thanks in advance,
Max
Re: Failed 582n Firmware Upgrade, stuck on PPPoA
18-02-2013 11:58 PM
19-02-2013 12:12 AM
19-02-2013 1:07 AM
19-02-2013 10:12 AM
Downloaded 'R8CM0 DG FTTC' but I can't log in to my router throughh the update utility.
This is the worst router I have ever used, I'm going to have to go to PC world - will any cable router do the job?
19-02-2013 11:49 AM
Page load times seem to be much much faster too.
I've never said a bad word about plus.net, but this router may make me think twice before referring anyone (especially to a fibre service, though I'm led to believe this is the ADSL modem too)
19-02-2013 12:29 PM
19-02-2013 12:41 PM
Quote will any cable router do the job?
Yes it should do, FYI but you'll probably already know that cable routers with a built in VDSL cable modem whilst being useful can be very expensive.
Adam
19-02-2013 1:49 PM
I seriously cannot believe how much faster pages are loading, I'd been using Fibre for a week prior to these problems and its night and day. Using the TN router page loading seemed hardly any better than when I was on 3mb.
I appreciate it was my fault upgrading the firmware wrongly, but the config seemed so slow it didn't seem right to me so wanted to try something.
19-02-2013 3:25 PM
19-02-2013 3:53 PM
19-02-2013 7:50 PM
19-02-2013 7:53 PM
Quote from: Matt http://products.plus-payh.co.uk/firmware/
It might be useful to add 10.2.2.B to that site so more people can get it and test it.
Edit: 10.2.2.B is on that site.
19-02-2013 10:04 PM
20-02-2013 3:03 PM
