FTTP I would like it
nay27uk
Hi are you doing FTTP (Fibre To The Property) in my area yet I would like to try it as what I am on with you at the moment (fastest package Fibre) I am lucky to get 52Mbps down and 11Mbps up, had your engineers round and BT replace stuff but still not getti ng advertised speeds. So I would like FTTP please
2 REPLIES 2
Fixes: 1,495
Re: FTTP I would like it
This will tell you whether FTTP is available at your property, https://www.broadbandchecker.btwholesale.com/#/ADSL
It's not currently available with Plusnet, but a staff member mentioned it would be in the very near future.
Fixes: 117
@nay27uk
As @dvorak  mentioned there are two separate issues. One is can you get it at your property - you need WBC FTTP in the left hand column of the Checker mentioned.
Second is currently PlusNet don't offer a service so if you were desparate you would need to change provider.
