FTTC
- FTTC
FTTC
27-04-2012 10:14 AM
OK, probably not the right area to ask to this but can anyone point me in the right direction of an answer on FTTC:
My exchange (Lincoln) says its enabled for 'some areas' - when I go to the BT Wholesale website I am still showing as poor speeds and no FTTC available.
So as far as BT are concerned the exchange is enabled (so technically they have met their target) but the fact of it not actually being available for the majority of the city still remains!
has anyone seen anything that points to a more detailed source of information, like when street cabinets will be upgraded, instead of when the exchange will be updated as all the lists refer to the exchange - which as you can see, can be misleading.
thanks
thanks
Message 1 of 2
(647 Views)
1 REPLY 1
Re: FTTC
27-04-2012 12:18 PM
Message 2 of 2
(234 Views)
