FTTC with TG582n not fit for purpose
- FTTC with TG582n not fit for purpose
Re: FTTC with TG582n not fit for purpose
27-10-2012 9:27 PM
Quote from: CX [You can use the BT/Huawei modem plugged into the WAN port (Ethernet port #4) on the Draytek. I don't think it matters if you use your own router, the problems occur when you use an alternative modem. From what I've read, the original Huawei modem may connect more faster and more stable than the Draytek's internal modem anyway.
Doesn't that defeat the object of replacing both boxes with just the one in the Draytek ?
27-10-2012 9:38 PM
If it's because you're disappointed with the performance from the TG582n, then I'd say not. Sure you could go for a cheaper router but at least you know that the processor inside the Draytek can actually route the traffic at the speeds demanded by FTTC (or you may want some of its other features - QoS, load balancing, 3G failover etc).
If it's because you wanted to replace both boxes, then sure.
27-10-2012 10:00 PM
I supoose that puts a different perspective on it knowing wether you want to change it to just using one box for for the reason you mentioned but what advantage would you have by using the original OR supplied modem over the draytek apart from if there was any issues that need to be resolved in the event of a fault occuring ?
27-10-2012 10:07 PM
I'm not sure where the official demarcation point is for FTTC installs. Logic suggests it's still at the NTE5 but I've read comments that BT consider the LAN side of their modem to be it with FTTC. I don't know which is true.
28-10-2012 12:06 AM
Quote from: mushy Can you confirm the wether the HH3 is type A or B, either way I thought they was locked to BT and you couldn't change the username and passord
Home Hubs since (I think) version 2.0b are usable with all BT based services, so Plusnet connections are able to use them without any reflashing of firware, etc. I have used a 2.0b and am currently using a 3.0a with few problems.
The HH2 used to crash when viewing line stats, but not every time, and the HH3 locks up after several weeks on-line. I think the available memory for the event log fills up, and a restart of the router fixes it.
28-10-2012 9:39 AM
The point is that plusnet are supplying substandard equipment and they need to be held to account for that.
28-10-2012 11:33 AM
Good luck.
28-10-2012 12:04 PM
Put it back in its box and order your preferred router from elsewhere. Plusnet are not going to supply a Draytek, Bipac or other premium brand as a standard router because not only is it going to be totally over the top for the majority of their customers, but something like a Draytek would likely just confuse them. By all accounts the supplied router is perfectly adequate for most customer's needs (as with the TG585 supplied with ADSL before it), just not so much for power users.
Car analogies usually work with computers, so how's this - how many of you have bought a car and found the supplied radio to be pretty poor compared to what you could buy aftermarket? It does the job, it's standardised, just not the best out there.
Now, what I would like to see if the option of choosing a "premium" router when signing up, as with some other ISPs. I could see how it could create some issues with support, as the support agents would need training in the other models available, but no worse than when people are using any old router.
28-10-2012 12:17 PM
28-10-2012 12:19 PM
28-10-2012 12:21 PM
28-10-2012 12:29 PM
Quote from: jelv Interesting how much Plusnet charge for these routers if you cancel before 12 months is up considering this.
A little cheaper on Amazon.
Maybe PN could specify a premium model or two that they would be happy to offer "broadband issue" support on, then let the power users source them if needed.
28-10-2012 1:18 PM
The comparison to a car radio does not really cut it either as that is not a primary function of the car, a better way of putting this would be if you go out and buy a car even the cheapest new car you can find it must be able to achieve at least 70mph as its primary function is 'driving'
The primary function of the TG582n is to route the connection internally inside your home, it is not there to connect you to the internet as the BT box supplied does this and is fit for purpose i.e. it can handle the 80/20 speeds, the TG582n's only primary function is to connect your home devices, however it cannot do this at the level required it would be like buying a car that only manages around 30mph i.e. not fit for purpose.
I am still stunned that plusnet tried to use the 'it has the same chipset as the bt home hub' argument.... oh really then why is it so vastly inferior and what are you going to do about it?
28-10-2012 1:40 PM
28-10-2012 2:01 PM
