FTTC very disappointed by the speed
- Re: FTTC very disappointed by the speed
22-08-2013 5:18 PM
Message 1 of 6
(1,103 Views)
5 REPLIES 5
22-08-2013 5:27 PM
Obvious things to check
What does this say https://portal.plus.net/my.html?action=data_transfer_speed and were those results wired or wireless or homeplugs
Message 2 of 6
(541 Views)
22-08-2013 5:28 PM
Looks like that test may have been done on wifi was this the case or did you do it via cat 5?
Message 3 of 6
(541 Views)
22-08-2013 5:31 PM
That page says
My entire LAN is 1Gb wired, I only use wireless for my Amazon Kindle, I have no homeplugs.
Is there anyway to get any information from the BT modem without resorting to uploading custom firmware?
What is Plusnet's attitude to me using my own VDSL modem?
Right have found at least part of the problem.
My professional UTM router. Having disabled just about the whole thing I now get
However, having checked the specs, with everything disabled, it's supposed to handle up 130mbps.
Quote Estimated line speed:
62Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-07-23 14:01:28
Current line speed:
78 Mb
Quote Download speed achieved during the test was - 46.58 Mbps
For your connection, the acceptable range of speeds is 16 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
Message 4 of 6
(541 Views)
22-08-2013 7:11 PM
The IP profile gives you the sync speed - multiply it by 1.033
It would be worth trying a connection direct to the modem and see what that gives
Message 5 of 6
(541 Views)
23-08-2013 10:06 AM
Everything seems OK with your connection after having checked it, as Oldjim mentions, it would be worth trying a direct connection to your modem and see if there's an difference.
You would need to setup a PPPoE connection for this.
PPPoE on Windows
PPPoE on MAC:
From the Apple menu, choose System Preferences
From the View menu, choose Network
Choose Built-in Ethernet from the Show pop-up menu
Click the PPPoE tab
Select the checkbox for Connect using PPPoE
Enter the Broadband Username and Password
Click PPPoE options and tick the Connect automatically when needed checkbox
Click Apply Now
PPPoE on Windows
PPPoE on MAC:
Click the PPPoE tab
Click Apply Now
Message 6 of 6
(541 Views)
