FTTC upto 80Mbps
- FTTC upto 80Mbps
Re: FTTC upto 80Mbps
17-05-2011 1:25 PM
BT actually announced "roughly double", and everyone has translated that into "approx 80Mbps", but the less-precise follow-up only ever sees the "80Mbps". IIRC, One of the reports says that BT has seen 70Mbps in the labs, without further qualification on the distances or environment simulated in that lab environment. Here's a link to an older report on that, which incidentally reports that South Korea's 100Mbps network averages 30Mbps because of congestion...
However, it seems likely that the lab environment is either ideal, or set to simulate a real-life case. That means we should think of the 70Mbps level as either the best-possible target, or a reasonable target, but not the 80Mbps.
BTW - this article says that NICC gave BT permission to run at 17MHz a week ago. Two years ago, the frequency extensions were perceived as useful to cases where fibre went to a building (ie multi-dwelling blocks) or to a distribution point (out on the poles) only, so getting permission to use the first 17MHz extension in the wild, and from cabinets, is quite a reasonable leap. I wonder if it will go to 30MHz.
I also wonder if the current modems are capable of the 17a profile
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
17-05-2011 2:58 PM
Quote from: markg140 why not claim "upto" what people actually achieve instead of some rounded up arbitary protocol number.
Cause 'sales people like nice round numbers... unless of course it's a price, in which case, it'll always be .99
18-05-2011 10:50 AM
Looks like this is true.
18-05-2011 10:56 AM
18-05-2011 10:57 AM
18-05-2011 6:07 PM
Quote from: WWWombat BT actually announced "roughly double"
Looks like I got that wrong. In one place, they announced merely "roughly double", but in a later location, they actually announced "roughly double... to up to 80Mbps".
BT PR
If BT don't sort out their ordering system soon, my yet-to-be FTTC will be able to do 80Mbps before it has even tried 40.
20-05-2011 11:41 AM
20-05-2011 9:55 PM
24-05-2011 5:07 PM
The graph isn't inaccurate when it shows fast speeds - BT undoubtedly limit the sync speed artificially for closer properties. However, it does look to be "optimistic" - in that it doesn't seem to take account of crosstalk from neighbour's installations.
This graph may be better, and explicitely does include crosstalk. The graph actually gets closer to BT's checker's estimates; note though that it shows the 8d profile, which is slightly higher power than BT's 8c profile.
24-05-2011 6:21 PM
25-05-2011 1:52 AM
25-05-2011 10:03 AM
Check this badboy out.
Uploaded with ImageShack.us
Worth noting on other tests I've seen 18MB upload.
25-05-2011 11:27 AM
25-05-2011 11:31 AM
You obviously had the right tea & biccies for that installation!
25-05-2011 11:36 AM
That's just the speed BT test to my house bypassing Plusnet's profile.
Thats why it says IP Profile set to 38717 or whatever.
Haven't come close to that again only had a 50, 72 and 45MB down.
Seen an 18MB up was like [Censored]!
Still think there's something dodgy with my connection.
EDIT: Scrap that just got a 73MB down and 14MB up.
It's strange its either I get 18MB up and about 50 down or I get 75ish down and 14 up.
EDIT2: Prove because it did happen.
