FTTC to ADSL, need new firmware. Help!
arclife
Hi all.
I've moved from an area with FTTC to an area without. Phone line is almost live. However my router doesn't have any opinions for ADSL, only FTTC.
Where do I get, and how do I flash a firmware so I can use ADSL.
Thanks Smiley
1 REPLY
Re: FTTC to ADSL, need new firmware. Help!
Hi arclife,
The firmware flashing tool, the different firmwares and the instructions on how to use both are at http://products.plus-payh.co.uk/firmware/ - hope that helps you get things sorted. I'm afraid the tool will only work on Windows, I'm not sure if there's a version available for either OSX or any flavour of *nix - if there is we're not aware of it.
