FTTC to ADSL, need new firmware. Help!
- FTTC to ADSL, need new firmware. Help!
30-10-2013 1:14 PM
Hi all.
I've moved from an area with FTTC to an area without. Phone line is almost live. However my router doesn't have any opinions for ADSL, only FTTC.
Where do I get, and how do I flash a firmware so I can use ADSL.
Message 1 of 2
(548 Views)
1 REPLY 1
Re: FTTC to ADSL, need new firmware. Help!
30-10-2013 3:27 PM
Hi arclife,
The firmware flashing tool, the different firmwares and the instructions on how to use both are at http://products.plus-payh.co.uk/firmware/ - hope that helps you get things sorted. I'm afraid the tool will only work on Windows, I'm not sure if there's a version available for either OSX or any flavour of *nix - if there is we're not aware of it.
Message 2 of 2
(282 Views)
