FTTC - the "missing" Mbps
- FTTC - the "missing" Mbps
06-02-2012 9:19 AM
This phenomenon is discussed on http://forums.thinkbroadband.com/plusnet/f/4089092-fttc-speeds-on-full-sync.html but I have seen it mentioned before, especially by WWWombat.
Can anyone from Plusnet offer an explanation for this? Can anyone explain the true meaning of the Plusnet current line speed of "37Mbps" which is the default for FTTC connections with the maximum sync?
Re: FTTC - the "missing" Mbps
06-02-2012 9:59 AM
I can see some discussion is already underway about this here http://community.plus.net/forum/index.php/topic,100862.msg861070.html#msg861070 I can also see we've raised this with our suppliers. I'll chase it up now.
I've made an adjustment to the profile on your account. Could you let us know if that's changed anything?
06-02-2012 11:10 AM
In November I was getting a transfer rate of 33Mbps and noticed that my Plusnet Line Speed was set at 35Mbs so I was losing 2Mbps then. Jojo adjusted my Line Speed from 35Mbps to 37Mbps and that increased my transfer speed to 35Mbps.
Does this 2Mbps loss apply to all Plusnet FTTC customers?
(There's been some chat about the missing 2Mbps at thinkbroadband, The latest thread is here.)
06-02-2012 1:06 PM
06-02-2012 1:23 PM
06-02-2012 1:43 PM
James
06-02-2012 2:35 PM
06-02-2012 2:41 PM
06-02-2012 2:51 PM
06-02-2012 3:10 PM
06-02-2012 3:14 PM
Quote from: _Adam_Walker_ Can I get you to reboot your modem (to drop and re-auth) the connection please.
Just a reminder that you could, in re-connecting, accidentally end up on a fast (37.5Mbps) connection anyway, even if it is rare. You might want to try connecting (& testing) a few times, to gain confidence that it has really changed something!
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
06-02-2012 3:15 PM
Quote from: KevinG OK Adam, I've done that and it has completely crippled the connection, now coming in at about 0.25!
That very much sounds like one of the "default" management profiles. that is set to 256kbps, I think.
Another reconnect?
06-02-2012 3:27 PM
06-02-2012 3:29 PM
Yes, in theory, just that I hadn't had such a connection for as long as I could remember but as soon as Adam did what he did I got one, and although I've had various other anomalies I haven't been back to one of the 2Mb slower connections since, so it looks fairly promising that the cause of the 2Mbps drop is near to being established.
Quote from: WWWombat Just a reminder that you could, in re-connecting, accidentally end up on a fast (37.5Mbps) connection anyway, even if it is rare. You might want to try connecting (& testing) a few times, to gain confidence that it has really changed something!
06-02-2012 4:42 PM
Quote from: KevinG I've rebooted the router (not the modem this time.....) and I'm back up to 37.5Mbps on speedtest.net.
Intriguing - I don't think that rebooting the router should change the synch speed already established at the modem. Doesn't it just change the ppp session and possibly the gateway? It looks as though the throughput changes are caused by something in the Plusnet system.
