FTTC speeds slowly dropping
- Re: FTTC speeds slowly dropping
19-11-2013 11:02 AM
Hi all,
I migrated to an FTTC service approx 4 weeks ago. I was quoted that my sync speeds would be 62 down and 20 up. For the first couple of days this is exactly what I got.
Over the last few weeks my sync speeds have steadily dropped and they are now 36Mbps down and 10Mbps up. Restarting the router etc appears to have no impact.
BTW Performance test shows the following:
Download speed achieved during the test was - 32.68 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-35.09 Mbps .
Additional Information:
IP Profile for your line is - 35.09 Mbps
Upload speed achieved during the test was - 7.13Mbps
Would a line reset achieve any improvement in speed?
Many thanks.
Many thanks.
Message 1 of 6
(954 Views)
5 REPLIES 5
19-11-2013 11:04 AM
Hi shamus,
A DLM Reset would push the speeds back up, but it's only likely to be a temporary fix if I'm honest. We would ideally be looking to see what has caused the sync speeds to drop so much.
Have you noticed any disconnections at all?
Message 2 of 6
(552 Views)
19-11-2013 11:30 AM
Hi Chris,
The only disconnections that I have noticed is when the up time of the PPPoE session resets.
Could we try a DLM reset?
Message 3 of 6
(552 Views)
19-11-2013 11:32 AM
If you could raise a fault at http://faults.plus.net they'll be able to raise some further in depth checks on your line and if they feel that the DLM needs resetting, they will be able to get you an engineer out to do that for you.
Message 4 of 6
(552 Views)
19-11-2013 11:39 AM
Thanks Chris,
Fault raised...
Fault raised...
Message 5 of 6
(552 Views)
19-11-2013 12:12 PM
Great - our faults team will get that looked at for you within 48-72 hours.
Message 6 of 6
(552 Views)
