FTTC speeds seem to be capped at 40/10 - should be 80/20
- Re: FTTC speeds seem to be capped at 40/10 - shoul...
02-06-2014 7:13 PM
Or have I got something wrong? Before I raise a ticket. Or not. It's been like this since installation a few weeks ago.
Re: FTTC speeds seem to be capped at 40/10 - should be 80/20
02-06-2014 7:22 PM
Was that test run wired or wireless?
dick:quote
02-06-2014 7:25 PM
I think this depends on a number of things...
1. Did you sign up for the UNLIMITED Fibre service? If no then you will be on 40/10, if yes then there is the possibility that you are incorrectly on 40/10, but see below.
2. What is your CURRENT SPEED as shown in the PN portal here - https://portal.plus.net/my.html?action=data_transfer_speed - if this is below 40Mbps that could cause your line to be apparently configured as 40/10
3. There is a fault on the line - raise a fault report here - http://faults.plus.net
Your BTw speed test rather suggests that you are not on 40/10, so my money is on either (2) or (3) above.
02-06-2014 7:41 PM
I am on the full-fat £19.99 UNLIMITED package
Estimated line speed:
38Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2014-05-02 18:20:41
Current line speed:
51.8 Mb
I have no line fault. Never have had...! Clean.
02-06-2014 7:42 PM
Quote from: jelv Was that test run wired or wireless?
02-06-2014 7:47 PM
02-06-2014 8:07 PM
02-06-2014 8:20 PM
03-06-2014 9:44 AM
Here's your line stats:
Downstream Speed: 43.3 Mbps
Upstream Speed: 9.8 Mbps
You are syncing a little lower than we would expect, but not by much. You can raise a fault with us at http://faults.plus.net and our Faults Team will take a look for you.
03-06-2014 9:48 AM
04-06-2014 8:14 PM
Plusnet info:
Phone exchange:
OAKHAM
Current line speed:
51.8 Mb
04-06-2014 10:01 PM
04-06-2014 10:03 PM
Cheers
05-06-2014 9:29 AM
05-06-2014 10:05 AM
