FTTC speed,s
rongtw
Fixes: 12
FTTC speed,s
I have been eagerly awaiting FTTC  Wink but the old Mr BT keeps bouncing my dates forward  Sad .
Now the question is as far as i was aware FTTC speeds were 40 down & 10  up ,, am i correct ? if you were lucky you could get the 80/20 trial .
But now i just checked BT wholesale Page & it says ??  am i lucky  Smiley or if i ever get FTTC will i only get the 40 ,
Fixes: 62
Re: FTTC speed,s
On Plusnet (not trial) you will get 40/2 not 40/10
rongtw
Fixes: 12
Re: FTTC speed,s
What i was saying was ,  ta for the correction Jim  Wink , according to BT wholesale , see attachment i am able to get 80/20  Smiley
But PN FTTC is 40/2 normal only 80/20 trial , but if mr BT says 80/20  when i get green light from BT would i be on 40/2 or the 80/20 ?Huh
jojopillo
Re: FTTC speed,s
Hi rongtw,
You would be on 40/2. However, you could then apply to be on the 80/20 trial.
Jojo Smiley
