FTTC speed,s
- Re: FTTC speed,s
FTTC speed,s
15-04-2012 5:16 PM
I have been eagerly awaiting FTTC but the old Mr BT keeps bouncing my dates forward .
Now the question is as far as i was aware FTTC speeds were 40 down & 10 up ,, am i correct ? if you were lucky you could get the 80/20 trial .
But now i just checked BT wholesale Page & it says ?? am i lucky or if i ever get FTTC will i only get the 40 ,
Message 1 of 4
(1,047 Views)
3 REPLIES 3
Re: FTTC speed,s
15-04-2012 5:22 PM
On Plusnet (not trial) you will get 40/2 not 40/10
Message 2 of 4
(324 Views)
Re: FTTC speed,s
15-04-2012 10:36 PM
What i was saying was , ta for the correction Jim , according to BT wholesale , see attachment i am able to get 80/20
But PN FTTC is 40/2 normal only 80/20 trial , but if mr BT says 80/20 when i get green light from BT would i be on 40/2 or the 80/20 ?
Message 3 of 4
(324 Views)
Re: FTTC speed,s
16-04-2012 1:16 PM
Hi rongtw,
You would be on 40/2. However, you could then apply to be on the 80/20 trial.
Jojo
Jojo
Message 4 of 4
(324 Views)
