FTTC speed problems
- Re: FTTC speed problems
FTTC speed problems
21-02-2013 8:46 PM
Hi I wonder if anyone can help?
I've had my FTTC broadband for about a month. I'm on the unlimited 80/20, i know when it was first connected i had the wrong 40/10 set up, which was changed.
I was promised 65mpbs and my line profile says my line should be up to 77mpbs.
It is very rare that i get anywhere near the predicted 65mpb, it's usually around 50mpbs,if I'm lucky but as you can see from the screen shot attached the speed is down to around
12mpbs both ways !!!
ANY help or ideas would be great.
adie:red removal of all caps title as per link:rules
Message 1 of 8
(1,645 Views)
7 REPLIES 7
Re: FTTC SPEED PROBLEMS
21-02-2013 8:50 PM
Are you connected wired/wireless?
Btw, it's easier to paste those results as an image by clicking 'Share this result'. It also hides your IP.
Message 2 of 8
(786 Views)
21-02-2013 8:52 PM
Thanks for that, I'm connected using a homeplug system
Message 3 of 8
(786 Views)
21-02-2013 8:54 PM
Any chance you can connect via ethernet cable directly to your modem to test the speed?
This would rule out any speed problems with your home plug setup.
Message 4 of 8
(786 Views)
21-02-2013 9:00 PM
I tried that when the FTTC was first installed, and it made no difference between direct connection and homeplug.
i just did a BTW speed test result shown.
As I said the speed changes for no apparent reason !!, but never seems to get to the predicted speed
Message 5 of 8
(786 Views)
21-02-2013 9:34 PM
I'm hoping that the tech guys might pick up on this
Message 6 of 8
(786 Views)
22-02-2013 11:53 AM
If you haven't done any recent tests straight over ethernet rather than via the homeplugs it would definitely be worth it just to rule it out - we couldn't raise a fault (if that's what this is) without those results anyway I'm afraid.
Any chance you could try it and paste a screenshot?
Message 7 of 8
(786 Views)
22-02-2013 2:51 PM
Hi
It seems very strange, but Ive been doing speed test throughout the day ... and my speed seems to have gone up to around 60/65 mpbs !!
Lets hop it's all's well that ends well.
Thanks for all the help everyone.
Message 8 of 8
(786 Views)
