FTTC speed plummet
- Re: FTTC speed plummet
FTTC speed plummet
27-01-2013 8:19 PM
Anyone else having issues or is it just me?
Line #1 - Parents Line: (Karian)
Estimated line speed:Not recorded (service activated before we introduced estimates)
Current line speed:61.6 Mb
Which gateway?
You are currently connected to the gateway known as ptn-ag02.
This is located in Telehouse North.
It's worth noting ive just swapped this account from Plusnet Extra Fibre to Unlimited.... and its taken me almost 10 minutes as the page keeps failing to load (the pretty spinning circle animation is getting rather tedious).... Site a little sluggish too?
Line #2 - My Line: (Matt2k34)
46Mb (Accurate to within +/- 1Mbit) - Checked on 2012-12-28 16:46:58
Current line speed:
54 Mb
Which gateway?
You are currently connected to the gateway known as pcl-ag01.
This is located in City Lifeline House.
Exchange = Swadlincote(OLO = EMSWADL)
Exchange capacity is shown as Green up until the 11th at least - as shown Here
P.S. - this is really getting on my wick...
Regards
edit: B0rked a tag
27-01-2013 10:51 PM
27-01-2013 11:13 PM
Sounds like congestion, Which is annoying as there's sod all that can be done other than poke BT. Awesome
Regards
edit: Might be worth PN noting this, as it looks like they need to poke BT rather than actually look at your line (unless there's an underlying issue)
27-01-2013 11:28 PM
Other ISP users reported speed issues too at peak times - http://community.bt.com/t5/BT-Infinity/CAN-ANYTHING-BE-DONE-ABOUT-CONGESTION/td-p/752162
http://community.bt.com/t5/BT-Infinity/CAN-ANYTHING-BE-DONE-ABOUT-CONGESTION/m-p/758516
27-01-2013 11:31 PM
Well great. Means im stuck with this POS until BT get their finger out.
Thanks AndyH
Regards
27-01-2013 11:36 PM
I'm on a 100/15 FTTP service and my free Sky 48.5dB connection was faster last week!
28-01-2013 12:08 AM
Quote from: AndyH @ Matt_2k34 - Your exchange is on Sky's list of congested exchanges (not sure how this works with LLU, but Sky have an upgrade scheduled for mid Feb).
:)think your right I've had bt out twice to say there's nothing wrong with the line,they've even come out with some bull that the adsl signal is bleeding into my pairs!what it just thought it start in December! Ironically though my neighbour is with SKY and his is fine during 6pm -12pm just waz in my wounds
28-01-2013 12:29 AM
Understand congestion, just they really need to sort it - it wouldn't be so bad if it was generally stable at that speed, I'm getting 3 then 20 then generally going up slowly
Regards
28-01-2013 1:38 AM
/coat
28-01-2013 1:46 AM
28-01-2013 1:48 AM
Quote from: dvorak If it helps mine's up and down between 68 and 71 all the time. Shocking.
/coat
you poor thing
28-01-2013 2:46 AM
Its just cause im lagging in DOTA atm, which is annoying me.
Regards
28-01-2013 4:38 AM
Yep. looks like capacity.
Bugger. Might as well tell PlusNet to call off the search Trickz
Regards
Matt
28-01-2013 10:06 AM
Quote from: Matt_2k34 I know you stuck your oar in just cause it's me Adie
ofc, it's called payback
28-01-2013 11:20 AM
[Censored]. Might as well tell PlusNet to call off the search Trickz
Regards
Matt
:-\What can I do now though? I can't keep having a bt engineer out to tell me my lines fine and having days off work,Plusnet please sort bt out.
