FTTC speed banded ?
Ian06
Fixes: 5
FTTC speed banded ?
I have been using a BT Smart Hub 2 for a couple of months now and it has been running my network a lot faster than my old Hub 1.
However my line appears to have become banded at 13Mbps ( I was previously stably connected at 16 to 18Mbps.)  The line seems quite good for the distance from the cabinet and  the connection was happily staying up for 8 to 10 days or more.
However we have had a 3 or 4 power outages recently (UK Power Networks repairing some nearby overhead cables apparently) and the modem connection speed now only connects at a fixed 13Mbps.
Can someone check if DLM has 'banded'/'placed a cap on' the line speed and reset it please...
Many Thanks
Here is the info screen from the router (this was taken about 9:30 this morning, the SNR gets worse in the evenings & overnight:
6 REPLIES 6
Ian06
Fixes: 5
Re: FTTC speed banded ?
In case it helps the other usual data is
adamwalker
Fixes: 223
Hi there @Ian06, I've just performed a line test which confirms banding is in place. I've submitted a DLM reset which should sort that out within the next 24 hours. Please give us a shout back here if there's any issues beyond that.
 Adam Walker
Ian06
Fixes: 5
@adamwalker Hi nothing seems to have changed.   I just restarted the router and the conection speed is the same at "Data rate:  547 Kbps / 13.095 Mbps"  Looks like the reset didn't happen...
Can you try again.... ?   Thanks
adamwalker
Fixes: 223
Sorry to see that Ian and sure, I've put another reset through so that should take effect soon. Please get back to me again if there's any further issues but I hope that does the trick.
 Adam Walker
Ian06
Fixes: 5
@adamwalker
Many Thanks, that seems to have been done now (about 20 mins ago) and my d/l speed is now much faster.  I'll keep an eye on it and see if DLM changes it again over the next couple of weeks.
Many Thanks....
adamwalker
Fixes: 223
Marvelous, I'm glad to see that's worked this time and do give us a shout again if there's any further problems.
 Adam Walker
