FTTC modem dropping packets?
Fixes: 10
http://status.aa.net.uk/apost.cgi?incident=1854
Does this affect Plusnet users?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 6
Re: FTTC modem dropping packets?
Thanks for the link.
Would be nice if they specified which of the two different makes of BT fibre modems are affected.
nokiboi39
Saw there was a further update on the link believing BT's latest update to FTTC modems is causing the issue on this basis and the picture shown on the link to the webpage http://revk.www.me.uk/ ; it looks like the HG612.  It also says BT is working on this.
Has PlusNet heard of this issue ?
Not before now, no - at least not to my knowledge. Not seen many reports of VPN issues either. At least we're aware of it now though, we'll have to see how it pans out I guess.
Fixes: 10
You hadn't heard of it? Surely you had as a result of the regular bulletins that BT send to all ISPs to keep them informed of any current issues!
[me=jelv]watches more bacon go past the window[/me]
Fixes: 234
Quote from: npr
Seems to be the Huawei ones - http://revk.www.me.uk/2013/11/bt-huawei-fttc-modem-bug-breaking-vpns.html
I've got an ECI one and have noticed any issues with the 2 VPNs I have running.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
