FTTC installed but speed quite far from IP profile given
fiscelan
I got my Fiber broadband (80Mb) installed today. While I can see a huge difference with what I had before, I'm somehow surprised to not have a quicker download as expected.
The IP profile given by PlusNet is the following:
Postcode:
Phone exchange: BERMONDSEY
Estimated line speed: 80Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-10-16 11:59:21
Current line speed: 78 Mb
However the BT Wholesale speed test gives me the following:
Download (Mbps): 59.17
Upload (Mbps): 15.7
And most of the speed tests I did on the Net gave me a download closer to 50 Meg...
Does this look right to you?
Thanks for your help
Vincent
fiscelan
Re: FTTC installed but speed quite far from IP profile given
Just to add I did already reboot the OpenReach modem but it looks like no improvements (do not want to do this too often).
Are you testing via a wireless or cabled link between the router and your computer ?
fiscelan
Hi Picbits,
Good point. Wireless. I tried wired but got limited to 10 Mb. My laptop has a Gb Ethernet port, I believe the PlusNet router too?Huh
Or is it the cable? Getting confused!
I've checked your sync speed and you're currently at 80Mb/s download and 20Mb/s upload,.
I'd try the wired connection again.
fiscelan
Thanks Chris.
Ok I've finally managed to test by wire properly.
Better results:
1; BT Wholesale: Down: 73.4, Up: 10
2. http://www.mybroadbandspeed.co.uk/.
Strange results there (and ran it 3 or 4 times, similar results): Down: 40, Up: 8
3. http://www.speedtest.net/
Down: 69, Up: 15.6
Does that leads me to conclude I do not have any pb on the line and with the profile but that the PlusNet router is only average?
fiscelan
I seem to be capped at below 50 in download wirelessly...
Advise to invest in a better router?
Mybroadbandspeed is notoriously unreliable - believe the speedtest results more than the mybroadbandspeed.
Getting 50-60mb/s wirelessly is pretty good actually - I only manage around 40-45 on my laptop and that is with a TP-Link 300Mbs router (not the Plusnet one).
Personally I think you'll find the 50Mb+ is fine for 99% of everything you do so maybe stick with your current router and see if you are happy.
Also try thinkbroadband for a fairly accurate speed checker.
Welcome to Plusnet by the way Cheesy
fiscelan
Thanks Picbits and Chris for your help by the way!
Smiley
deathtrap
Thinkbroadband speedtest, accurate? Maybe is when it works properly, On and off i get really low upload speeds in the results, low as in less than 50% of my upstream throughput, that tester or any of the transits that feed it aren't that reliable,And the  slow upload results have been like that for weeks, I don't have the same issue with speedtest.net ,
http://www.thinkbroadband.com/speedtest/button/138339712856280473184.png  http://www.speedtest.net/my-result/3074012125
