FTTC install
- Re: FTTC install
FTTC install
05-10-2013 11:09 AM
Re: FTTC install
05-10-2013 11:11 AM
However, you can now use your Vigor as the modem and router with no problems: the rules have changed on using your own modem (you can now).
Hopefully, Plusnet will be providing a combined VDSL modem/router soon (from what we know, it is to be the TG589v3).
Re: FTTC install
05-10-2013 11:14 AM
I have just noticed that they sent me a TG582n recently when I joined PN with the standard ADSL service. Still in it's box as I am using the Draytek. If the TG582n is for a fibre install, does this mean they sent me the wrong router when I ordered the ADSL in the first place?
Re: FTTC install
05-10-2013 11:31 AM
Plusnet use the same router for both ADSL and FTTC connections but they run different firmware. The FTTC version converts one of the LAN ports to be a WAN port.
Re: FTTC install
05-10-2013 11:35 AM
Although, Plusnet may just end up sending you another one anyway. Did you choose to get one when you ordered?
Re: FTTC install
05-10-2013 11:39 AM
If you use your own router, Plusnet may request you use the router they supplied in the event of a fault so don't throw it away...
Re: FTTC install
05-10-2013 11:46 AM
Re: FTTC install
05-10-2013 11:53 AM
Re: FTTC install
20-12-2013 6:56 PM
I have a TG582n no usb
So, yesterday I placed my order for FTTC.
Openreach are attending Dec 27th, plusnet said I needed new router. In the Christmas post by now I presume
If the new router doesn't arrive, will I be able to upgrade the existing one ? as the firmware (http://products.plus-payh.co.uk/firmware/) for fttc only refers to the 582 with USB port ? and there are two versions
Re: FTTC install
20-12-2013 7:06 PM
When I was with PN I got a USB port when I ordered fibre. That was back in June 2012 so it may have changed.
I've thrown away the TG582n sept 2012 as I acquired a BT home hub which worked on PN then I left PN to BT.
So most of the time I was with plus net I had my own preferred router.
