FTTC drop in speed
- FTTC drop in speed
- « Previous
- 1
- 2
- Next »
Re: FTTC drop in speed
30-07-2014 5:45 PM
Thanks, Chris. My speed still hasn't improved, and it's almost at a point where it's not worth my paying for the Fibre Extra package (as opposed to Fibre).
If I raise a ticket, can you change my DLM profile from "Standard" to "Speed" to improve things?
Message 16 of 21
(381 Views)
30-07-2014 7:23 PM
@garywood sadly There are no such options on fibre like there are on ADSL your stuck with what you have until DLM chooses to change that and that's if it chooses to do anything at all, as i said in a previous post here it's been two months plus for me with no change despite everything being clear to do so, It's a very very long annoying waiting game.
Message 17 of 21
(381 Views)
31-07-2014 12:13 PM
@terranova667 - According to <a href="http://www.openreach.co.uk/orpg/home/products/super-fastfibreaccess/fibretothecabinet/fttc/downloads/GEA_FTTC_4.pdf">this BT Wholesale fact sheet</a>, and information I've read elsewhere, there are 3 FTTC DLM profiles available from BTw, and ISPs can choose how to provision each customer.
Message 18 of 21
(381 Views)
31-07-2014 1:20 PM
Yes, there are, they are called 'Policies'. Depending on which policy you're set to, will depend on how quickly DLM reacts/makes changes to your line.
They are called:
Standard, Stable and Super Stable - that's what BT Wholesale call them anyway.
They are called:
Message 19 of 21
(381 Views)
01-08-2014 12:54 PM
Thanks, Chris. So how do those Plusnet labels match the BTw ones in their briefing document in my link above? And how can I get my line changed to Speed?
Message 20 of 21
(381 Views)
01-08-2014 2:42 PM
Hi garywood84,
Our naming should align in the same order as BT so we have Standard, Stable and Super Stable which equates to BT's Standard, Stable and Speed.
Unfortunately we don't really offer the ability for customers to switch between these at the moment as it is a manual process in order to configure an order and then raise a request through to the supplier for the changes to be made.
In addition to this there are also risks involved with moving between the different options as a line may not be able to support the change up in the bandings and could well suffer a fault as a result of this which is another reason why we're not keen on offering these types of alterations.
Message 21 of 21
(381 Views)
- « Previous
- 1
- 2
- Next »
