FTTC disconnects, crackly line and lower speed
Pettitto
Fixes: 5
Re: FTTC disconnects, crackly line and lower speed
I'm glad that's been sorted out for you.
As a network change has been made, I'm going to see what options we've got to get a DLM Reset sorted out for you - DLM could take a while to bring you back to where we'd like you to be.
Leave it with me and I'll see what I can do Smiley
markbaguley
Chris - A DLM reset would be great Smiley  Thanks for your help!
Fixes: 159
Mark,
A DLM reset on FTTC needs a broadband engineer visit.  Crazy
You might be left with waiting for the DLM to sort things out, unless (as per last post) Chris can find some magic.
Kevin
markbaguley
Damn! I was hoping for the digital care team to have a DLM magic wand somewhere in the office Tongue
Pettitto
Fixes: 5
Quote from: Townman
That's true in most cases Smiley
Like any process, there has to be a workaround. There is a team within BT Openreach who are able to do remote DLM Resets, in case an engineer doesn't or isn't able to do one on the day. I'm seeing if I can get them to do it, given the circumstances.
This isn't normal process, but I don't see the point sending out another engineer solely for a DLM Reset Smiley
Fixes: 159
Chris,
If you take the whole of my quote, it is true all of the time...
EITHER
"You wait for the DLM"
OR
"Chris can find some magic"
WOW BTOR have a work around process which deals with the foibles of the real world - GREAT NEWS - is it new news learnt from your recent sojourns to BT's smokey towers in the Deep South?
If you can pull off this bit of magic, then you should think about a try out on "Britain's got talent".
Kevin
Pettitto
Fixes: 5
Haha, well I'm quite happy to work with BT Wholesale and BT Openreach and they fully appreciate when such issues fall outside of the normal process and they can be accommodating - it's all about the relationship you have between ISP and supplier Smiley
I wish I was magic, that'd be pretty awesome!
markbaguley
It would appear that someone is working on my line right now...at least I hope that's it as I've got a oscillating tone on the line which sounds like the BT testers!
Fixes: 159
Could that be the call minder message waiting tone?
See http://www.plus.net/support/phone/call_features.shtml#voicemail for instructions on managing this feature.
markbaguley
Definitely not, it's there even if I ring 17070 or any other number.  Sounds exactly like what the engineer was using to find my line in the junction box.
markbaguley
And now it's gone, hopefully a nice engineer doing a DLM reset Smiley
Pettitto
Fixes: 5
Right, that's been sorted for you.
That's increased from 27.9Mb to 65.7Mb. I've updated your speed profile so a quick restart of your router should do the trick to bring your speeds back up Smiley
markbaguley
Thank you very much Chris - this is the level of customer support which keeps people with Plusnet Smiley
Everything looks perfect now:
Pettitto
Fixes: 5
Thanks!
Just glad I was able to get that sorted out for you Smiley
Mardler
Impressive.
