FTTC disconnects, crackly line and lower speed
- FTTC disconnects, crackly line and lower speed
20-05-2014 5:44 PM
I had my FTTC service activated on the 16th with a sync speed of 67/18. I mentioned to the engineer at the time that my line was noisy but he said the self test was fine and I agreed that if the speed was good then maybe it was an issue with my cordless phone or just not affecting the broadband. Since then I have noticed multiple disconnects on the router and my speed has decreased to 20/10. Also if I call up 17070 I can see the DSL light on the openreach modem go out - essentially when I am on the phone my broadband will disconnect.
I have a ticket open at #85840351 but I thought I might get more useful help than an automated response on here.
Thanks,
Mark
Re: FTTC disconnects, crackly line and lower speed
20-05-2014 6:07 PM
If yes the engineer fitted the new faceplate, do you have another phone[corded ideally] to test with plugged into the master socket?
If after all that the noise is still there, then you got a useless engineer, report a phone line fault to who ever provides your phone line.
20-05-2014 6:16 PM
20-05-2014 6:23 PM
Also my phone provider is Plusnet so it's all in their hands.
20-05-2014 6:57 PM
That is really good news... no Ping-Pong between voice and broadband providers for you.
Have you go a friend you could borrow a phone from?
What happens when you get an inbound call - does it cause the BB to drop? If it does, that could be a duff filter or a line fault, which ties in with your noise.
Kevin
20-05-2014 10:46 PM
21-05-2014 10:04 AM
For us to progress the issue, would you be able to reply back to Ticket: 85840351?
21-05-2014 11:41 AM
https://drive.google.com/file/d/0B_KPrw-cnRY4U0tvaE52aGVENmM/edit?usp=sharing
21-05-2014 11:47 AM
21-05-2014 11:52 AM
21-05-2014 12:10 PM
21-05-2014 12:15 PM
21-05-2014 12:22 PM
22-05-2014 10:11 AM
There could be a multitude of things they might do. They'll attach stuff to your line - Hawk box / test head / own hand set / tone generator - to aid diagnostics.
Ask what fault they've found, if they say none, ask if a fault might be detectable if the line is tested from the cabinet.
I have seen situations where no fault can be found with the pair quality test equipment when tested from the nte5 box. "If there is a fault this baby will find it, if it says there is no fault, there is no fault." On that and a subsequent occasion the Eclipse Exit Test (automated test from the exchange initiated by engineer's mobile phone and reports back to the mobile) reported a loop fault, which was dismissed as a test head issue.
Third engineer said that was not right, tested the line from the cabinet and found the fault.
Make sure you get a clean eclipse test before the engineer leaves.
22-05-2014 10:21 AM
