FTTC but DL 3.5mb (ul is 17mb!)
- FTTC but DL 3.5mb (ul is 17mb!)
Re: FTTC but DL 3.5mb (ul is 17mb!)
17-04-2013 4:55 PM
I connected via my PC directly and got a ~78mb DL!
Then without doing anything else plugged my router back in and tested again and ~72mb DL...
So no idea but all is good.
Thanks to all very much!
17-04-2013 5:02 PM
Just out of interest, how and what equipment did you have set up when you were getting the lower speeds?
17-04-2013 5:10 PM
So nothing different at all from what was getting the 20mb.
17-04-2013 5:12 PM
Quote Then without doing anything else plugged my router back in and tested again and ~72mb DL...
The two pppoe disconnects/reconnects could well have put you on a different gateway. There was a problem with ptn-ag01 yesterday.
17-04-2013 5:14 PM
You are currently connected to gateway pcl-ag02.
17-04-2013 5:48 PM
21-04-2013 3:12 PM
All was good for a few days until Saturday, then the connection dropped for a while and when it reconnected the speed is down to ~4mb.
Still with the fast upload.
At the moment I am on gateway: pcl-ag03
Ivan
22-04-2013 12:18 PM
Quote from: Kelly There will be line training, but that is about bringing your line down to a stable speed.
This smells like a fault to me! Chris and/or Chris will be investigating for you.
Hi Kelly
I seem to have an issue again, please see what you can.
22-04-2013 2:22 PM
22-04-2013 3:21 PM
Yip, I have rebooted the openreach router several times, seen gateways 1,2,4,5
Always the speed is ~4mb now though.
22-04-2013 3:46 PM
22-04-2013 4:02 PM
Quote from: jelv To change gateway it's just the Plusnet router not the OpenReach modem!
Ok, either way it hasn't helped.
22-04-2013 5:02 PM
22-04-2013 5:13 PM
Done thanks.
23-04-2013 9:46 AM
I've just popped an update on the Fault ticket you've raised.
