turn on suggestions
FTTC available ?
- FTTC available ?
FTTC available ?
FTTC available ?
04-12-2011 10:49 PM
have been awaiting FTTC
acording to http://www.openreach.co.uk/orpg/home/products/super-fastfibreaccess/downloads/sffa_exchange_lists/ac... my exchange is taking orders , ? is this just for BT or are PN going to supply me if i ask nicely
can one of our super PN staff here check , my exchange is undercliff Code: MYUND west yorkshire
Re: FTTC available ?
04-12-2011 10:53 PM
See what it says for you own line here
https://www.btwholesale.com/pages/static/Community/Broadband_Community/Coverage/ADSL_Availibility_Ch...
cheers f9o
cheers f9o
04-12-2011 11:00 PM
This site will tell you when Openreach will roll out FTTC and when.
http://www.superfast-openreach.co.uk/where-and-when/
& this page for Plus Net http://www.plus.net/fibre-broadband/?source=mainNav
05-12-2011 9:00 AM
cheers but it still ambiguous
TheIslander your link is what i saw and tells me BT are taking orders NOW
but Force9Original link says 30th december
is the live date
05-12-2011 9:06 AM
Or you could try phoning Openreach. Their phone number is 0800 0232023
05-12-2011 9:39 AM
As understand it........
The only definitive way of determining whether 'you' can order FTTC is by using the BT ADSL availability checker on your phone number.
The various published pdf's only give a broad outline of the progress.
It may well be that the exchange is converted to service FTTC but until the actual cabinet which is serving your property is upgraded and activated then you cannot
either receive or pre-order FTTC.
Cabinets are not enabled all at once and it may be that some cabinets on the exchange are done a considerable time before others - and indeed there are times when certain cabinets are not done at all under current plans due to various "issues".
The availability checker may give some expected date (which sometimes "changes") so until it actually states that it is available for you to order and the service is live or whatever words they actually use-------you'll have to wait.
05-12-2011 10:15 AM
cheers for replys ,, thing is i can actually see the new box they fitted ouside my house
07-12-2011 6:43 PM
Update
my new box is now active for FTTC
so have ordered it , cross fingers all goes fine 15th
