FTTC VDSL: Yesterday 72Mbps Down, today only 9 Mbps. Speed dropped by 63Mbps
- FTTC VDSL: Yesterday 72Mbps Down, today only 9 Mbp...
21-05-2014 10:03 AM
Re: FTTC VDSL: Yesterday 72Mbps Down, today only 9 Mbps. Speed dropped by 63Mbps
21-05-2014 10:07 AM
It's worth keeping an eye on things but we'd need to allow the line to train itself for the initial week.
21-05-2014 10:08 AM
21-05-2014 10:12 AM
Quote from: Chris Your line hasn't been active very long, it's still going through it's initial stabilisation period which lasts around a week or so.
Thank you Chris for quick reply. I thought that a week of training was for ADSL service and not VDSL? As VDSL is always on training and keeps adjusting synchronisation speed?
Although, it might be different for initial synchronisation. Will keep an eye and report in a week.
21-05-2014 10:18 AM
ADSL has a 10 day training period, whereas VDSL has an open profile for the first two days to allow for engineers/customers to move their internal wiring if required.
After that the line finds that band it needs to be on and DLM closely monitors the line. Once the line has remained stable, it'll stick with the band that you're set on. If line conditions change, for example, if if your line begins to error, DLM will take action overnight to make any adjustments to the banding and profile that you're assigned.
21-05-2014 10:25 AM
My wireless will give me results from 10Mb - 40Mb/s depending on which way the wind is blowing while a wired connection usually gets me >60Mb/s
21-05-2014 10:51 AM
adie:quote
adie:red please don't remove moderator comments.]
21-05-2014 11:06 AM
I think I've had to do that three times in the past 17 months and certainly not for any speed issues in the last 10+ months.
22-05-2014 9:23 AM
Day1 - Activation Day
Before FTTC activation: D:10Mbps, U:1Mbps (ADSL)
After FTTC activation : D:73Mbps, U:19Mbps
Day2 - Download speed dropped from 73Mbps to 9Mbps. Upload: 19Mbps
Day3 - Still the same. D:9Mbps, U:19Mbps
I hope that Download speed will go up. Surely this isn't right even for the service that has been just activated? Could there be issue with Qos on my profile that PlusNet has?
Router DSL Statistics:
Receive Direction Send Direction
Max. DSLAM throughput kbit/s 80000 20000
Min. DSLAM throughput kbit/s 128 128
Attainable data rate kbit/s 78668 19999
Current throughput kbit/s 78668 19999
Seamless rate adaptation off off
Latency fast fast
Impulse Noise Protection 0 0
G.inp off off
Signal-to-noise ratio dB 6 3
Bitswap on on
Line attenuation dB 22 15
Profile 17a
G.Vector off off
Carrier record B43 B43
22-05-2014 9:32 AM
Your line stats look fine to me, please see attached.
22-05-2014 9:41 AM
I could setup BT Modem again, but just don't want to affect my line by disconnections if it is in training phase. Or will it be OK for me to disconnect FB and get BT Modem plugged in?
22-05-2014 9:43 AM
22-05-2014 9:57 AM
Check here: https://portal.plus.net/my.html?action=data_transfer_speed (log-in required).
22-05-2014 10:41 AM
22-05-2014 10:43 AM
