FTTC VDSL: Yesterday 72Mbps Down, today only 9 Mbps. Speed dropped by 63Mbps
tomcemerka
Yesterday I got upgraded to FTTC VDSL. Everything looked great. Synchronization speeds were D:76Mbps U:19.9Mbps. Speedtest gave me results of D:73Mbps, U:19Mbps  Cheesy
22 REPLIES 22
Pettitto
Fixes: 5
Re: FTTC VDSL: Yesterday 72Mbps Down, today only 9 Mbps. Speed dropped by 63Mbps
Your line hasn't been active very long, it's still going through it's initial stabilisation period which lasts around a week or so.
It's worth keeping an eye on things but we'd need to allow the line to train itself for the initial week.
tomcemerka
Today - completely different story. Download speed dropped by 65Mbps  Cry
tomcemerka
Quote from: Chris
Thank you Chris for quick reply. I thought that a week of training was for ADSL service and not VDSL? As VDSL is always on training and keeps adjusting synchronisation speed?
Although, it might be different for initial synchronisation. Will keep an eye and report in a week.
Pettitto
Fixes: 5
No problem.
ADSL has a 10 day training period, whereas VDSL has an open profile for the first two days to allow for engineers/customers to move their internal wiring if required.
After that the line finds that band it needs to be on and DLM closely monitors the line. Once the line has remained stable, it'll stick with the band that you're set on. If line conditions change, for example, if if your line begins to error, DLM will take action overnight to make any adjustments to the banding and profile that you're assigned.
picbits
A question that I don't think has been asked - are you testing via a wireless connection or straight to the router via ethernet cable ?
My wireless will give me results from 10Mb - 40Mb/s depending on which way the wind is blowing while a wired connection usually gets me >60Mb/s
tomcemerka
Good question. I should have mentioned that basics were covered already. Tested connectivity using LAN cable connected directly to the Router.
adie:quote
adie:red please don't remove moderator comments.]
picbits
The other issue I had when first connected was a gradual decrease in speeds over a few days down to <10Mb/s - a quick log on to the router, manually disconnecting then reconnecting solved this.
I think I've had to do that three times in the past 17 months and certainly not for any speed issues in the last 10+ months.
tomcemerka
Experience on PlusNet FTTC so far:
Day1 - Activation Day
Before FTTC activation: D:10Mbps, U:1Mbps (ADSL)
After FTTC activation    : D:73Mbps, U:19Mbps
Day2 - Download speed dropped from 73Mbps to 9Mbps. Upload: 19Mbps
Day3 - Still the same. D:9Mbps, U:19Mbps
I hope that Download speed will go up. Surely this isn't right even for the service that has been just activated? Could there be issue with Qos on my profile that PlusNet has?
Router DSL Statistics:
Receive Direction Send Direction
Max. DSLAM throughput kbit/s 80000 20000
Min. DSLAM throughput kbit/s 128 128
Attainable data rate kbit/s        78668 19999
Current throughput kbit/s 78668 19999
Seamless rate adaptation        off off
Latency fast       fast
Impulse Noise Protection        0 0
G.inp off off
Signal-to-noise ratio dB        6 3
Bitswap on on
Line attenuation dB       22 15
Profile  17a
G.Vector        off off
Carrier record B43 B43
Pettitto
Fixes: 5
What setup do you have Are you still using the Openreach Modem? If so, what speeds do you get directly connected to that?
Your line stats look fine to me, please see attached.
tomcemerka
I got Fritz!Box 7490 VDSL Router connected directly into DSL socket. VLAN:101, VPI:1, VCI: 32, Encapsulation: PPPoE, annex B (as for 17a Type Profile - recommendation http://community.plus.net/forum/index.php?topic=127136.0)
I could setup BT Modem again, but just don't want to affect my line by disconnections if it is in training phase. Or will it be OK for me to disconnect FB and get BT Modem plugged in?
Pettitto
Fixes: 5
It'll be fine for a couple of disconnections - it'll be interesting just to see if the line behaves any differently with regards to throughput.
Jaggies
Could this not perhaps be a late Delta Report, dropping the Current Line Speed to ADSL levels?
Check here: https://portal.plus.net/my.html?action=data_transfer_speed (log-in required).
Fixes: 1,483
we haven't seen the BT profile have we?
Pettitto
Fixes: 5
The profile set on our side is set correctly.
