FTTC Speeds are half of Line Sync
- Re: FTTC Speeds are half of Line Sync
26-10-2013 11:06 AM
Hey everyone, having a small issue with my service.
joined plusnst from sky , and signed up for the FTTC Fiber unlimited product.
I was connected up yesterday and after 12 hours ran a speed test and got around 38.9mbps
This morning I have ran the BT Wholesale speed checker (img2) and have worse numbers, even though my max sync speed is over 77mbps
I have power cycled the modem trying to get it to re-sync but the 2nd test came out at a lower speed than the first.
How long should I be waiting to get my estimated speeds of 66.6mbps as tbh I find getting under half of that a bit unacceptable.
I have read the speed guide and ran all the tests / suggestions and now i'm out of ideas
thanks for all the help
Message 1 of 6
(1,280 Views)
5 REPLIES 5
26-10-2013 11:10 AM
what does this say https://portal.plus.net/my.html?action=data_transfer_speed for current line speed and were those tests wired or wireless
According to the IP profile you are synched at 80Mbps
Message 2 of 6
(691 Views)
26-10-2013 11:11 AM
Hi there.
I've had a quick look over your connection and I can't see any reasons for the poor speeds
Can you go through the troubleshooter below and raise a fault so we can investigate further?
https://portal.plus.net/apps/kbdfaults
Any further issues please give us a shout
Message 3 of 6
(691 Views)
26-10-2013 11:35 AM
IGNORE ME
Sorry, after a 7 hour drive from london to nevcastle last night im still apparently asleep and forgot that my Media Center (where i ran the test) was running though a 400mbps denovo homeplug which killed the speed. Ran it on Ethernet through my laptop and got 76mbps down and 10mbps up.
total noob mistake I know, so now i have to find someway of running a cat6 cable through the house without tearing up floors or drilling holes.
Joys lol
Thank you so mush for your quick reply's guys
Joys lol
Message 4 of 6
(691 Views)
26-10-2013 11:40 AM
Message 5 of 6
(691 Views)
26-10-2013 2:49 PM
yeah, only thing I need to do now is replace the plusnet router with the new asus one i have ordered
jim:quote
jim:quote
Message 6 of 6
(691 Views)
