FTTC Speed locked to old property speed?
- FTTC Speed locked to old property speed?
25-03-2012 4:40 PM
Did a house move with Fibre and was told by the engineer on the install that I should be getting the full 40MB speed - however speed tests haven't got over 15MB (which incidentally around the fibre speed I was achieving at my old property - however now i'm much closer to the green cabinet) - is there something that needs to be done on my account that will 'unlock' the full speed?
Here are the results from the BT Speed checker:
Thanks for any help.
Message 1 of 8
(1,558 Views)
7 REPLIES 7
Re: FTTC Speed locked to old property speed?
25-03-2012 4:43 PM
In addition - Plusnet report of current line speed - this hasn't changed and was set to this at my old property:
Message 2 of 8
(735 Views)
25-03-2012 5:04 PM
The Plus Net profile (current line speed) needs updating, this will be slowing you down to below 19Mbps, the 'correct' figure should be 37Mb.
Call me 'w23'
Message 3 of 8
(735 Views)
26-03-2012 11:47 AM
Quote from: walker23 The Plus Net profile (current line speed) needs updating, this will be slowing you down to below 19Mbps, the 'correct' figure should be 37Mb.
Thanks for the info - that would explain it..
Whats the best way about doing this?
Message 4 of 8
(735 Views)
26-03-2012 11:53 AM
Unfortunately we can't see the images as we don't have dropbox access from the office. Can you attach them to your post?
When creating a post click the Additional Options and Attachments... link and you can upload directly to the forums.
Message 5 of 8
(735 Views)
26-03-2012 11:58 AM
Quote from: Chris Unfortunately we can't see the images as we don't have dropbox access from the office. Can you attach them to your post?
I've attached the images to this post.
Thanks.
Message 6 of 8
(735 Views)
26-03-2012 12:26 PM
Thanks, I've tweaked your profile on our systems. What speeds are you seeing now?
Message 7 of 8
(735 Views)
27-03-2012 4:17 PM
Quote from: Chris Thanks, I've tweaked your profile on our systems. What speeds are you seeing now?
Hi Chris,
Much better about 28mb - will see if this settles over the next few days.
Message 8 of 8
(735 Views)
