FTTC Slowing Down Below Estimate
- Re: FTTC Slowing Down Below Estimate
25-05-2014 7:09 PM
Unable to get any stats from the routers.[Moderator's note by Dick(Strat) All caps title edited as per forum rule.
26-05-2014 1:47 PM
http://speedtest.btwholesale.com/ ;
26-05-2014 8:15 PM
27-05-2014 11:14 AM
From looking at your screenshot, it looks as though you're running the Speed Test via Wireless. What results do you get with an Ethernet Cable connected?
27-05-2014 3:51 PM
27-05-2014 4:05 PM
Would you be able to raise a fault at http://faults.plus.net and we'll get this looked into for you?
27-05-2014 4:36 PM
I hope we can improve the situation.
cheers...
30-05-2014 12:33 AM
I have enclosed latest speedtest results
30-05-2014 9:54 AM
30-05-2014 12:41 PM
However line is clear now 12.30am(noon)?
30-05-2014 12:59 PM
It could be an intermittent issue. From memory, does this happen at a particular time?
30-05-2014 1:05 PM
30-05-2014 1:15 PM
30-05-2014 2:43 PM
30-05-2014 4:27 PM
I've moved your Fault Ticket to our Faults Team so that they can take a look at the speed side of things. I'd expect an update within the next 48-72 hours.
