FTTC Slow Speed
NewGuy20
FTTC Slow Speed
Hi Guys,
Been on fibre for just under a week now, on fibre unlimited. My estimate for my connection was 61.2mb, my BT IP profile appears to be 77.44 according both plusnet and the BTW speed tester however I cannot seem to set anymore than about 39mb.
It is possible something was missed when my account was upgraded to FTTC? I know my upgrade was done manually as the system didn't swap me over for some reason.
Re: FTTC Slow Speed
That's very likely. Either give PN a call or raise a fault via the website. This forum is unmonitored over the w/e & public holidays.
Re: FTTC Slow Speed
I've checked over your connection and your current sync speed and profile is in the high 70Mb/s. I'd suggest running through our faults troubleshooter at http://faults.plus.net and we'll take a closer look if you're still having issues.
