FTTC PPPoe will it work
- FTTC PPPoe will it work
23-04-2013 6:44 PM
I have a Belkin Share N300 adsl modem model no F7D3402 v1.
I notice in the setup screen there is an option for PPPoe. Does this mean I would be able to use the router part of this device alone in conjunction with the new BT FTTC modem?
Curious does has anyone else got this router on fttc.
podman
podman
Message 1 of 6
(1,331 Views)
5 REPLIES 5
Re: FTTC PPPoe will it work
23-04-2013 7:00 PM
Yes, I think you can on some Belkin models that can auto-sense what sort of connection you have
Message 2 of 6
(537 Views)
23-04-2013 7:31 PM
No - This is an ADSL router and does not have the ability to use a LAN port as a WAN port.
Although PPPoA is the most common config for ADSL, PPPoE is also an option. (Bulldog and Be originally used PPPoE for example)
Message 3 of 6
(537 Views)
23-04-2013 7:35 PM
Cheers, thought I'd check before I place my order on Thursday.
Podman
Podman
Message 4 of 6
(537 Views)
23-04-2013 10:51 PM
Have you powered up the router? I have a Belkin N300 and it definitely has an option to be used as a wireless access point
Message 5 of 6
(537 Views)
24-04-2013 7:49 AM
That's not what the OP asked though -They want to use it as a router.
Message 6 of 6
(537 Views)
