FTTC PPPoE FIrewall
- FTTC PPPoE FIrewall
FTTC PPPoE FIrewall
22-12-2011 10:10 PM
I am trying to set up PPPoE on my Juniper SRX210 firewall. I have an FTTC connection and am having no luck. Are there any specific settings I need to know? I have taken the rj45 ethernet cable which comes out (LAN side if you will) of the BT VDSL modem and plugged it into the firewall. The basic settings I have used are below but I am still getting a CHAP state : Closed. I believe that the firewall can see the plusnet servers as there is a "Remote MAC address: 00:30:88:00:00:05"
set interfaces fe-0/0/6 unit 0 encapsulation ppp-over-ether
set interfaces pp0 unit 0 ppp-options chap default-chap-secret *******
set interfaces pp0 unit 0 ppp-options chap local-name username@plusdsl.net
set interfaces pp0 unit 0 ppp-options chap passive
set interfaces pp0 unit 0 pppoe-options underlying-interface fe-0/0/6.0
set interfaces pp0 unit 0 pppoe-options idle-timeout 0
set interfaces pp0 unit 0 pppoe-options auto-reconnect 3
set interfaces pp0 unit 0 pppoe-options client
set interfaces pp0 unit 0 family inet mtu 1492
set interfaces pp0 unit 0 family inet negotiate-address
set routing-options static route 0.0.0.0/0 next-hop pp0.0
set security zones security-zone untrust interfaces pp0.0
Any Ideas?
Any Ideas?
Message 1 of 4
(1,770 Views)
3 REPLIES 3
Re: FTTC PPPoE FIrewall
23-12-2011 2:36 PM
Message 2 of 4
(730 Views)
23-12-2011 3:07 PM
Having a look about does suggest the following as a starting point.
http://kb.juniper.net/InfoCenter/index?page=content&id=KB15736#pppoe_ex1
Does also indicate some toubleshooting which may produce something meaningful.
Message 3 of 4
(730 Views)
24-12-2011 2:30 PM
Top Tip, Thanks
Message 4 of 4
(730 Views)
