FTTC Modem Change
- FTTC Modem Change
Re: Modem
15-02-2012 12:59 PM
Not worried about PSU as the consumption is less than 6 watts and runs cool after 24hrs.
Re: FTTC Modem Change
15-02-2012 1:18 PM
It wasn't until the Monday morning, when a letter from PlusNet arrived advising of the equipment change, that my mind was settled.
The appointment time has come and gone, so I hope the call I've now made to KC will initiate a callback with an explanation.
15-02-2012 3:04 PM
The engineer did NOT swap my PSU. Although in and out quickly he did wait until I confirmed all was well.
15-02-2012 5:03 PM
I queried the need for a replacement as I have already had mine replaced when it failed shortly after getting it. The engineer said the replacement was to do with the change in speeds that are coming and not failure of the modem.
My router now shows the date as January 2003 and there doesn't seem to be anyway to reset this. The manual says the router accesses a time server but it has now been connected for over an hour and it still shows Jan 2003. (Edit: It updated over 4 hours later)
15-02-2012 5:22 PM
It has nothing to do with a change in speeds. It is concerning that Kelly is giving out duff information.
If the router took a long time to reconnect I expect this is due to a stale PPP session. If you had disconnected the session before swapping the modem it would have reconnected with problem.
James
Re: Modem
15-02-2012 6:25 PM
15-02-2012 6:59 PM
15-02-2012 9:37 PM
Sent and email Friday eventing to Kelly Comms, got a phone call Monday morning offering any appointment time this week.
Picked Tuesday afternoon, it was a BT OR Van and engineer that turned up. Seems the Kelly guys did most of the BT NI FTTC customers, and the BT OR guys are mopping up the rest in 'Norn Iron'.
I also had to reboot the router a couple of times to reconnect, but once all was well the BT OR guy went on his way.
He did replace the PSU, so I have the white one now.
Never had an issue with the old one, never once felt hot, but always had it mounted vertically, on a cool wall near the front door - to keep it out of the way more than anything else.
15-02-2012 10:10 PM
Quote from: JEB If the router took a long time to reconnect I expect this is due to a stale PPP session. If you had disconnected the session before swapping the modem it would have reconnected with problem.
When the modem isn't being swapped (such as a power-cycle of the modem), the router is *much* quicker to respond, and retry PPP - so it seems unlikely that this is *just* a problem at PPP level.
I suspect that the issue is more to do with ARP caching, or whatever the equivalent on that WAN connection is called (PPPoE Discovery?) - where the router is caching the ethernet MAC address of the modem. If the modem is swapped (so the MAC address changes), but the router carries on trying to establish PPP to the old address, you'd see this kind of delay. As different routers probably employ different timeouts for these caches, you'd see different results.
A reboot o the router obviously will clear the cache quickly...
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
16-02-2012 8:42 AM
16-02-2012 9:13 AM
16-02-2012 9:34 AM
Quote from: TBSteve Got the letter on Friday, tried booking appointment online, but the reference number was reported as invalid
I don't suppose you noted down the error code did you? We've had a couple of reports of this and the next day the reference number worked.
Ex-Broadband Service Manager
16-02-2012 10:46 AM
All seems to be well.
16-02-2012 1:00 PM
16-02-2012 10:59 PM
Quote from: Kelly
I don't think there was an error code, just a message saying the code was invalid, and if problems persisted to email them, which they did. 🙂
