FTTC Line limits
machare
FTTC Line limits
Given that FTTC is available at a cabinet, what technical rules do BT/Plusnet apply in deciding whether a customer can be connected?
For example is it likely that a customer with 2km of cable between them and the cabinet would be connected?
What is the maximum cable distance that is likely to be connected?
1 REPLY
Re: FTTC Line limits
As far as we're aware there is no maximum distance (fibre is a LOT less resistive than copper) - so if the checker on our site says fibre is available for you, then we'll order it Smiley
