FTTC Line Speed Mystery
adagio
Telephone number:
    02380xxxxxx
Phone exchange:
    TOTTON
Estimated line speed:
    1.0Mb (Accurate to within +/- 1Mbit) - Checked on 2011-10-16 08:50:21
Current line speed:
    13 Mb
_________________-
BT Speedtest
> Download speedachieved during the test was - 35188 Kbps
For your connection, the acceptable range of speedsis 12000-38717 Kbps .
Additional Information:
IP Profile for your line is -38717 Kbps
______________________
This is not a complaint you understand  Wink
but would be interested in explanation
Re: FTTC Line Speed Mystery
PlusNet 'current line speed' should be set to 37Mbps (that's the figure they normally use for FTTC connections (certainly any working at full speed as yours is).
The strange thing is it is not slowing down your throughput (35188 Kbps is very healthy). Maybe the figure is mis-reported, either way it ought to be corrected, perhaps a PN rep will sort it when they see this (normally in working hours).
How long have you been on FTTC?  If only just connected it may have simply not been adjusted yet.
Call me 'w23'
adagio
Quote from: walker23
About 4 weeks. Ironically last week the situation was reversed, early last week Plusnet Line Speed said 35 Mbps my download speeds 12 Mbps. Had been on the verge of raising a ticket.
ffox
What does the  Plusnet "Current line speed" indicate?  Is it the Plusnet profile or just a number pulled out of the hat?  (Mine was 37Mb but it's now 35Mb although the BT profile hasn't changed from 38717.)
Fixes: 77
Hi adagio,
I've just performed another line check only to see the same thing. However it would seem that the 1mb figure is derived from what you'd be able to receive in terms of connection speeds over a copper line.
 Adam Walker
ffox
Hi Adam
Fair enough, but my question (and I think this is also adagio's question) is what does "Current line speed: 13 Mb" mean considering that the BT profile is 38717?
adagio
Quote from: _Adam_Walker_
Hi Adam
I assumed that to be the case it has always been thus! Long way from exchange hence the upgrade to FTTC. Just a bit mystified as to what Plusnet's "Line Speed" means in this context and what effect it might have on performance. A few minutes ago http://speedtest.net/ indicated 37 Mbps.
@ffox - your profile on the delta report side from BT is definitely at 13000, which is why ours is set to the same. If you've a screencap of the speed test results then we can update it from this side, though as soon as a new delta report comes through it'll drop again.
@adagio - it looks like the delta report (and our own profile) are both set to 35000 as things stand, perhaps that's why the speedtest result shows as it does?
adagio
Quote from: Matt
Matt
Plusnet Member Centre Speed  https://portal.plus.net/my.html?action=data_transfer_speed
still shows
Telephone number:
   023808xxxxx
Phone exchange:
   TOTTON
Current line speed:
   13 Mb
Just checked again and it's set to 13000 on both our and BTs side, looks like it's been like that since the start of November without an update. It might be worth turning the modem off for a few minutes and then back on again if you haven't done that already, but if you have I recommend raising a fault and we'll get it sorted for you that way.
reddev87
Just checked my "current line speed" and its set to 30Mb.
Even though im synced at the 39999k maximum limit, and my IP profile is 38717.
Strangely though, my throughput has not been impeded by PN's setting of 30Mb - current throughput is around 37.5Mbit.
lexusuk
Hi reddev87 and adagio,
I've discussed this with a member of our networks team and it looks like the profiles set on our network layer may not be controlling your speed as expected which is allowing you to achieve higher speeds than that which should be possible given the profiles assigned.  Although this is not causing either of you any issues at the moment we will investigate this and update via this thread.
reddev87
I wasn't complaining as such, I mean 37Mbit is what I should be getting, given that my IP profile is 38717 with a 39999 sync.
I just found it weird that A: PN have it set to 30Mbit, when it should match BT's IP profile, and B: My speed hasn't suffered because of it.
ffox
Why are there two profiles anyway?  I would have thought that one (BT's) was sufficient to provide any required control.  Two separate ones are a potential problem. Huh
caulbox
I have to say that I do tend to agree. Whilst I can appreciate there might be some instances when Plusnet need to exert control to override BT profiles for various technical reasons.....Couldn't (and shouldn't?) any such instances be treated as exceptions, leaving the BT profile as sufficient for the mainstream?
