FTTC Line Speed Mystery
- Re: FTTC Line Speed Mystery
14-11-2011 5:36 PM
Telephone number:
02380xxxxxx
Phone exchange:
TOTTON
Estimated line speed:
1.0Mb (Accurate to within +/- 1Mbit) - Checked on 2011-10-16 08:50:21
Current line speed:
13 Mb
_________________-
BT Speedtest
> Download speedachieved during the test was - 35188 Kbps
For your connection, the acceptable range of speedsis 12000-38717 Kbps .
Additional Information:
IP Profile for your line is -38717 Kbps
______________________
This is not a complaint you understand
but would be interested in explanation
14-11-2011 6:16 PM
The strange thing is it is not slowing down your throughput (35188 Kbps is very healthy). Maybe the figure is mis-reported, either way it ought to be corrected, perhaps a PN rep will sort it when they see this (normally in working hours).
How long have you been on FTTC? If only just connected it may have simply not been adjusted yet.
14-11-2011 6:25 PM
Quote from: walker23 How long have you been on FTTC? If only just connected it may have simply not been adjusted yet.
About 4 weeks. Ironically last week the situation was reversed, early last week Plusnet Line Speed said 35 Mbps my download speeds 12 Mbps. Had been on the verge of raising a ticket.
15-11-2011 7:07 AM
15-11-2011 9:48 AM
I've just performed another line check only to see the same thing. However it would seem that the 1mb figure is derived from what you'd be able to receive in terms of connection speeds over a copper line.
15-11-2011 9:54 AM
Fair enough, but my question (and I think this is also adagio's question) is what does "Current line speed: 13 Mb" mean considering that the BT profile is 38717?
15-11-2011 10:06 AM
Quote from: _Adam_Walker_ . However it would seem that the 1mb figure is derived from what you'd be able to receive in terms of connection speeds over a copper line.
Hi Adam
I assumed that to be the case it has always been thus! Long way from exchange hence the upgrade to FTTC. Just a bit mystified as to what Plusnet's "Line Speed" means in this context and what effect it might have on performance. A few minutes ago http://speedtest.net/ indicated 37 Mbps.
15-11-2011 2:11 PM
@adagio - it looks like the delta report (and our own profile) are both set to 35000 as things stand, perhaps that's why the speedtest result shows as it does?
18-11-2011 9:40 PM
Quote from: Matt @adagio - it looks like the delta report (and our own profile) are both set to 35000 as things stand, perhaps that's why the speedtest result shows as it does?
Matt
Plusnet Member Centre Speed https://portal.plus.net/my.html?action=data_transfer_speed
still shows
Telephone number:
023808xxxxx
Phone exchange:
TOTTON
Current line speed:
13 Mb
21-11-2011 11:30 AM
21-11-2011 12:19 PM
Even though im synced at the 39999k maximum limit, and my IP profile is 38717.
Strangely though, my throughput has not been impeded by PN's setting of 30Mb - current throughput is around 37.5Mbit.
21-11-2011 1:29 PM
I've discussed this with a member of our networks team and it looks like the profiles set on our network layer may not be controlling your speed as expected which is allowing you to achieve higher speeds than that which should be possible given the profiles assigned. Although this is not causing either of you any issues at the moment we will investigate this and update via this thread.
21-11-2011 1:46 PM
I just found it weird that A: PN have it set to 30Mbit, when it should match BT's IP profile, and B: My speed hasn't suffered because of it.
21-11-2011 2:53 PM
21-11-2011 3:33 PM
