FTTC Installation
plusnetdan
FTTC Installation
(previously posted under danplusnet which is an account registered under old address, this username is linked to my new property)
I have just taken out broadband and home phone with Plusnet. Property didn't have an existing number so was unable to order FTTC so I opted for an initial home phone and value broadband installation so I could get a phone number allocated. As soon as I got a phone number the system says I can have FTTC.
A few questions
1) My phone doesn't work as it has an exchange side fault which BT need to investigate. Does this need to be resolved before I can upgrade my order to FTTC?
2) My broadband is targeted to be active by 8th Dec (ignoring the above fault for the moment).There's a minimum delay of 1 week from order to installation of FTTC so I would like to order as soon as I can even though it may not be active until 8th Dec.  Do I need to wait for it to become active before I can order FTTC?
3) If a BT engineer needs to investigate the phone fault at the premises could he/she install the FTTC too?
Many thanks
1 REPLY
Fixes: 69
Re: FTTC Installation
Hi plusnetdan,
No, but it's probably a good idea to wait until that's resolved first
Yes, the broadband would need to be active first to allow us to change your account over to Fibre.
No, different types of engineers deal with faults as opposed to the ones that perform installations.
Let me know if you have any other questions at all.
 Adam Walker
